jerk while in freeway
We're looking at this problem now to narrow down the conditions which would cause the ECU to reboot.
met
Post by met »
Thursday I installed 1.4.2 and since then I haven't had it happen again. I have drove about 300 miles. Well if there is anything I can help with let me know. Thanks!
In the beta I have fixed a problem which was resetting the ECU, which could be the same problem as described here. If people with this problem could test the beta version and give feedback I'd appreciate it.
See SManager 1.4.6.0 beta for the changes and download link.
blackek4
Post by blackek4 »
Hondata wrote:In the beta I have fixed a problem which was resetting the ECU, which could be the same problem as described here. If people with this problem could test the beta version and give feedback I'd appreciate it.
how do we test it? just install the new beta, and upload our existing calibration to the ecu trough the new beta version? or do we have to make a new calibration based on the new beta version?
Just upload your calibration using the new version, like you do with all new versions.
blackek4
Post by blackek4 »
ok, thanks. i'll test it this weekend, and give the feedback here :wink:
met
Post by met »
I updated it around 3 before I left work and drove about 60 miles, no misses yet. I will update you guys in a few days.
Thanks!
EkJimmy
Post by EkJimmy »
i drive my wifes car everyday to school and home and notice it would jerk and goes back to normal happens about 3-4 times through out the day. Downloaded the beta and drove for 50miles so far so good. will give an update in a week and see how it does.
diSTiNCt
Post by diSTiNCt »
awesome!
Will try out the 1.4.7 version today!
Since everything else on my car was working fine.
Thanks for the feedback.
XPEHODATA
Post by XPEHODATA »
Yes. Jerks no more on 1.4.6.
EkJimmy
Post by EkJimmy »
is there any difference between 1.4.6 and 1.4.7 beta?
blackek4
Post by blackek4 »
couldn't drive as much as i wanted to test it properly, but the few miles i drove, no jerks. tested with 1.4.7.0.
good job hondata :wink:
met
Post by met »
I have drove over 300 miles on 1.4.6 and no resets, so im going to give 1.4.7 a try. On a side note, I changed a few settings I turned vtec pressure switch off and also turned in the internal barometer on.
snwbrdrx19
Post by snwbrdrx19 »
cant say the same here. the car ran much smoother but i still have my bad symptoms. looks like i got a fried ecu :(
