FlashProManager V1.1.5.6 (beta) - US MT R18 support
you can't, but you can upload a stock equivalent.
orangeclockwork
Post by orangeclockwork »
Is the Nitrous control in the list of future changes?
Thanks!
Nike
Re: FlashProManager V1.1.5.6 (beta) - US MT R18 support
Post by Nike »
to Hondata:
I have put R18 MT US ECU in canadian R18 civic. Everything (including FlashPro) is working, but the reverse is not blocked. It is possible to fix this?
Thanks.
Nike
Post by Nike »
Hondata,
1. Why have not removed the limit on the speed?
2. I have a set temperature turn cooler 96*C, but it is worked at 101*C. Why?
P.S. In advance, thank you.
What vehicle do you have, and what ECU are you using?
I suspect that the lack of reverse lock out is because you have a non-US vehicle with 6 speed.
#1 should be disabled, or is on a US vehicle at least.
#2 is probably because the fan defaults to using the second ECT sensor, on the outlet of the radiator.
Nike
Post by Nike »
Hondata wrote:What vehicle do you have, and what ECU are you using?
Hi!
I have 8th civic 4D, 6MT 2008 and US 5MT ECU 2006.
Hondata wrote:#1 should be disabled, or is on a US vehicle at least.
On dinostende restriction triggered by 124 mph =(
Hondata wrote:#2 is probably because the fan defaults to using the second ECT sensor, on the outlet of the radiator.
Gooood ) Thanks ;D
We do not recommend or support using a US ECU in a non-US vehicle.
Nike
Post by Nike »
Spunkster wrote:We do not recommend or support using a US ECU in a non-US vehicle.
Why?
I want to have Hondata, but for my car it's no support. What I do?
