KManager V3.0.3
kornshadow097
Re: KManager V3.0.3
Post by kornshadow097 »
I'm having an issue all of a sudden with Kmanager. It just started having a pop up error message at start up and it wont go in. It says "An Internal exception occured (Address: 0x7815ab)" from Hondata SManager. The address on it changes from time to time I believe. But it never opens now. I uninstalled and reinstalled 3 times and it wont work.
Jon
Re: KManager V3.0.3
What version of windows are you using?
kornshadow097
Re: KManager V3.0.3
windows 7 64bit. but it usually automatically installs into the 32bit folder so it works fine. Its been working til I ran a virus scan the other day.
Re: KManager V3.0.3
Try uninstalling the antivirus software and reinstalling Kmanager.
kornshadow097
Re: KManager V3.0.3
I did. It works now.
However, It is important that I keep my antivirus. It has a white list feature and I've already added kmanager.exe to it. What other processes can I add to make sure I dont get the error?
Re: KManager V3.0.3
You will need to contact the antivirus software manufacturer to determine what in their software is causing the false readings.
kornshadow097
Re: KManager V3.0.3
It isn't causing a false reading though. It seems to be blocking a process attached to the application. I'd like to know the list of processes so I can manually unblock them or put them on a whitelist. They dont have a number to contact...so I cant contact them in anyway without buying their software so I'd like to fix this myself (I'm a certified tech so just help me fix this)
Re: KManager V3.0.3
There is only one process: kmanager.exe
Our experience with the AV software is that even fully disabled they still can cause problems. Our recommendation is to use Microsoft Security Essentials, which is very good (free from Microsoft).
kornshadow097
Re: KManager V3.0.3
I see. Alright I'll look into that. Thanks for your help
Jon
shiggy
Re: KManager V3.0.3
Post by shiggy »
One of my customer has reported the datalog and cursor trace became very slow after updating from 1.5.1 to 3.0.3.
Windows is XP and it is only couple years old, also works OK with older version.
I made sure he updated the USB driver when he update to 3.0.3, he said he did.
When opening only the "display" window and "Graph" window, it is not that slow.
He said it becomes very slow when open all of display, graph and table windows simultaneously.
Any solution?
Re: KManager V3.0.3
Re-upload the calibration to the KPro.
The Spectacle
Re: KManager V3.0.3
Post by The Spectacle »
Hondata - just wondering if my last two feature requests have been given any thought in the development process for the next release
Boost Comp Air Temp Comp
viewtopic.php?f=12&t=12859
Boost Controller PID Control
viewtopic.php?f=12&t=12002
Re: KManager V3.0.3
My initial replies are still applicable. I will look again for the temp comp tables.
The Spectacle
Re: KManager V3.0.3
Thanks.
What frequency are the analog inputs sampled at? Any plans for some type of filtering? This is what my fuel pressure looks like:
The jittery signal is really hard to gather good data from. Here is a pic of the sender mounted on the stock fuel rail:
Re: KManager V3.0.3
The frequency depends on what method you are using to datalog.
Add capacitance between the signal and ground to smooth out the signal.
