Honda Accord CL9 Euro 03-08 Model Flashpro works
K_A_N_O
Re: Honda Accord CL9 Euro 03-08 Model Flashpro works
Post by K_A_N_O »
dinoc wrote:please do, sombody above reported it didn't work
yes it works, spread the word!
05 UKDM CL9 Accord.
CivicVTi
Post by CivicVTi »
It also works after a FD change to 4.764 (from stock Euro CL9 4.388).
dinoc
Post by dinoc »
That is great.
It allowed to adjust the speedo from the dashboard?
Euro Honda Accord CL9
CivicVTi
Post by CivicVTi »
With US ECU + 4.764 FD everything reads fine. Odometer, speedometer and cruise control. No need to change the speedometer correction value (left it at 0%). However, I set it at -3% to correct the speedometer error which seems to be high in ours cars (120km/h -> 112km/h on GPS). Odometer does not change with this correction only the speed.
Speedy_Gonzales
Post by Speedy_Gonzales »
How can i deactivate the EVAP error in my EU CL9?!?
angelf1974
Post by angelf1974 »
Speedy_Gonzales wrote:How can i deactivate the EVAP error in my EU CL9?!?
Honda Accord CL9 (Spain)
Speedy_Gonzales
With the Beta Flashpro Manager?
Speedy_Gonzales
Ok, done. Thanks ;)
TKR
Post by TKR »
I read the topic and I understood that there will be some errors after installing FlashPro to K24A3 Euro Accord (using Acura TSX 07-08 ECU, wiring kit and Hondata FlashPro Acura TSX 04-08). Those errors should be possible to disable with software options. Are those options available in all software versions or only specific ones? How you have solved this issue?
Wiring installations. OBD end should be quite clear for me, but the other end is not. Have you installed wires directly to the connector E (Acura ECU) or somewhere else? And how you have done it, soldering or using some crimped systems?
Thanx and sorry my english...
angelf1974
TKR wrote:I read the topic and I understood that there will be some errors after installing FlashPro to K24A3 Euro Accord (using Acura TSX 07-08 ECU, wiring kit and Hondata FlashPro Acura TSX 04-08). Those errors should be possible to disable with software options. Are those options available in all software versions or only specific ones? How you have solved this issue?
No errors.
Hondata wiring installations are good for Accord
Where are you from?
TKR
Post by TKR »
I am from Finland. In this topic some says that there is difficult to find right Can connector. Did you find it easily and was it just plug and play?
CL9 Accord is LHD here and in Britain RHD. I do not know how much differences there are between them. In Spain and here in Finland cars might be quite similar, I suppose.
You say that "no errors". I assume that you just disable those by software, right?
Immobilizer, who did this for you, local dealer or is this possible to do anyone who has Honda HDS?
Too much questions... ;)
angelf1974
Difficult to find, no. Difficult to plug Hondata kit, yes but not impossible. The CAN concennector is a little bit inaccessible.
Errors are easy to disable:
Immobilizer.... Honda dealer
