FlashProManager V1.8.3 beta (Bluetooth)
Re: FlashProManager V1.8.0 beta (Bluetooth)
IcEMoCHa wrote:I'm having the non bluetooth version of the flashpro. The latest firmware seemed to have fixed the button issue.
But now the flashpro doesn't turn on/turn off itself (no lights) when there is no activity and cannot datalog/program.
I have to unplug the obd and replug it in before it works.
What procedure are you going through to give the behavior?
IcEMoCHa
Post by IcEMoCHa »
My flashpro is left in car from previous datalogging session. Reached destination, turned off engine.
Later when I turned key to ignition position the flashpro power light comes on for a sec then off. After that, the flashpro stays off even after engine is started.
terenceng
Post by terenceng »
IcEMoCHa wrote:My flashpro is left in car from previous datalogging session. Reached destination, turned off engine.
excatly the same problem as one of my customers
however the flashpro is back to normal after a while.
hopefully it is just a bug.
thank you
soxfan143
Post by soxfan143 »
I'm having the same issue. I have to unplug the DLC connector every time I Shut the car off.
Can you check that you have firmware 63, not 62?
IcEMoCHa
Post by IcEMoCHa »
Hondata wrote:Can you check that you have firmware 63, not 62?
Mine is 63
soxfan143
Post by soxfan143 »
I am also on 63
mabo
Re: FlashProManager V1.8.1 beta (Bluetooth)
Post by mabo »
Damn , i had a drag today and my flashpro also been screwed with that update. It lives its own life now , turns off all the time , i cant catch it to be turned on to make a datalog or upload a cal... have to play with turn off on ignition and plug\unplug it to DLX . Fix it !
mabo
Post by mabo »
Forgot to add, 1.8.1 FPM , 63 FW .
VitViper
Post by VitViper »
The option to disable the fuel economy alternator control on the ILX calibrations is kind of a nuisance... I have customers in cold climates that are having trouble due to the battery drainage from this stupid "feature" Honda added lol
R-12914
Post by R-12914 »
I have also the same problem with my non bluetooth Flashpro on version 1.8.1 beta with FW version 63.
Please try and fix this problem!!!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
romeochris
Post by romeochris »
thank you
Just updated the firmware 63 into my FP and tried on my JDM FD2, problem still happen.
I have to plug the FP AFTER I switched to ON position, otherwise the FP will not turn on. Mine is non-BT version FP. Thx!
sass
Re: FlashProManager V1.8.2 beta (Bluetooth)
Post by sass »
Hondata ver. 1.6.3 fuel level in racing calibration was working fine on dash of FN2. In ver 1.8.1 and 1.8.2 fuel level fails + - 15-20
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
sass wrote:Hondata ver. 1.6.3 fuel level in racing calibration was working fine on dash of FN2. In ver 1.8.1 and 1.8.2 fuel level fails + - 15-20
We have not changed the race calibration code for the last year or so. You should be aware that this is a 'race' calibration, and the fuel level / economy will not work correctly on the FN2. Use a FN2 calibration with Speed/Density tables enabled.
VitViper
Post by VitViper »
We need P0128 disable on the 06-11 Civic Si calibrations -- I have customers throwing that code with low temp thermos (and my car has a low temp as well).
