PWM components installed?
mjalaly
Re: PWM components installed?
Post by mjalaly »
any other thoughts on what might be the issue?
what inputs does hondata need before you can test the PWM?? Like VSS signal maybe?? Or should it be able to test regardless of other inputs?? I am suspect the components are fine as the rear of the pcb (including these components) was covered in a sealent of some sort or potting material... it was professionally done.
No other inputs are needed when using the test function, just have your calibration loaded.
mjalaly
Post by mjalaly »
Crap then i dont know what to do... any other thoughts?
Try a different ECU, replace the components, test in a known working ECU in this vehicle.
mjalaly
Post by mjalaly »
I did replace the components and i don't have access to another ECU.. with hondata atleast
AREA876
Post by AREA876 »
Are you 100% sure it's connected right
mjalaly
Post by mjalaly »
Yup.
mjalaly
Post by mjalaly »
Any other options or should i just remove hondata and go with something else?
AREA876
Post by AREA876 »
Which ECU are you using
mjalaly
Post by mjalaly »
I have never known. There are no markings on the computer to identify it. The best i can provide is the pic on the 1st page.
