Injector Driver Box
Re: Injector Driver Box
It has not officially been released as we are still waiting on packaging.
SPOOLIN
Post by SPOOLIN »
Geez I'll take it in a plain ole box.
www.MSSRACING.com
9.29 | 6.20 | 167
sass
Post by sass »
Hondata wrote:Yes, that looks good.
OK
What price?
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
$395
Masterl1nk
Post by Masterl1nk »
hello! I've tried to buy the Injector Driver box but webpage says "out of stock".
We're still a couple of days away from selling.
The injector driver has now been released.
SPOOLIN
Post by SPOOLIN »
Mine came in today :)
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
Wired it up today and plumbed injectors! No turbo yet so no test yet.
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
Few questions:
1: is there a way to setup an indicator on the display to show when the staged injectors are active and also in data logs?
2: what should I expect to see in the data logs for injector duty cycle? Should they drop off instantly but maintain the same fuel delivery amounts since it's compensating for another set of injectors?... Giving me headroom to continue adding fuel where needed?
3: what would happen if I selected the option to run them in parallel verses staged? Would my car just die or does hondata calculate and compensate based on sizes selected?
This helps me to know what to expect as I go to make this work this week on the dyno and track.
www.MSSRACING.com
9.29 | 6.20 | 167
1. Use the indicator for the output used (ACC, PCS, IAB, FANC etc).
2. There is some correction for wall deposits, but injector duration and duty cycle will drop instantly. Fuel delivery stays the same.
3. The s300 would not need to control the injectors, so staged injection is not enabled and you would change the injector dead times. Gets more difficult with mis-matched injectors, but can be done.
SPOOLIN
Post by SPOOLIN »
ok i'm sticking with staged anyway.
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
Huge bug: turn on staged, set the settings....save the file....close hondata...reopen file, it's like I never turned it on. It uploads what I set it to but will not save it in the file.
Bug 2: set rpm and boost settings based on psi for the load....save the file...it reverts back to Kpa and a number for Kpa it decides to put.
I took a video of bug 1.
www.MSSRACING.com
9.29 | 6.20 | 167
Sorry about that, we fixed that problems and have a release:
SPOOLIN
Post by SPOOLIN »
thanks, i tested it and it works.
www.MSSRACING.com
9.29 | 6.20 | 167
