fuel pump prime issue and no ecu download
dc5itr01
Re: fuel pump prime issue and no ecu download
Post by dc5itr01 »
Problem diagnosed. Your updated software came with a virus. Confirmed this on another ecu also. Laptops both went crazy. Did all the same bad things.
Had to wipe the laptops and ecu clean. Reloaded newer version. All good. Couldnt use old tune file also. It became corrupted with your virus. Had to start from scratch. Strange thing is that the OEM wideband suddenly refused to be seen by kpro. Was using that as a test. Revert back to plx wideband and all works.
Still get the usual common kpro glitches though. Everyone does I guess.
Let's see how long everything holds out now!
On another note
Will a prc file work properly on a PRB board? Thinking of swapping boards for the extra outputs needed.
None of our software ever has contained a virus. Please do not spread rumors like this.
