Running Hondata Mobile on your radio/navi
Civic 2016+ 1.5 Turbo
turboroe
Re: Running Hondata Mobile on your radio/navi
Post by turboroe »
Why can't I add k control to the dashboard display? It shows in the list display but not in the dashboard list options
Check you are running the most recent build.
https://www.hondata.com/updates/link.php?app=dash
turboroe
Post by turboroe »
Hi Hondata, yes I am using latest version. I took some photos, please check.
On the Sensor list, I get KControl, but on the dashboard list Kcontrol does not show.
I also noticed that when editing the dash by holding the dash element, the options are always the Gauge options, even when holding precision analog or analog element. When editing by settings menu, then the other options show on precision analog and analog (although my KControl still doesn´t show up).
Another strange thing that happens is, I made a home screen shortcut for hondata, and sometimes I click on the shortcut and hondata opens, but other times I click several times the icon does nothing... other icons work fine, this only happens with hondata shortcut.
Sorry, the dash app can not display all of the available ECU channels.
turboroe
Post by turboroe »
Ok no problem. I also got the hondata2 paid app for my phone, but then I have the opposite problem. I can show the K Control on the dash view, but I can´t show K Count.
It would also be nice to have units in metric if possible.
Thanks!
You can change the units for the individual gauge you are using. It is not a global setting.
turboroe
Post by turboroe »
Ok, I was able to change the units individually.
Any way to get K. Count on the dash view ? It shows in the HU version of the app, so it should be mappable in this one too.
oasisfan
Post by oasisfan »
Is it possible to run the dash app without flash pro? or does it always have to be connected?
The FlashPro must be connected to get the data.
oasisfan
Post by oasisfan »
Not possible with a OBD2 Bluetooth Adapter?
No, you must use the FlashPro.
DneprM750
Post by DneprM750 »
Thanks for creating that tool, I've installed it on my car this morning and everything's working fine, I really feel like I'm driving in the future now!
But on a more serious note, I'll give you feedback as I use it; so far, everything's positive.
alex_hockey69
Post by alex_hockey69 »
After installing the hack. My android auto has disappeared? Any reason for this ? How to get it back ?
You will have to contact the makers of Honda Hack for this type of issue.
ponsit
Post by ponsit »
I tried to install Hondata Mobile Dashboard but got error below.
“warning: do not install untested apps which require root privilege.”
This error is from .apk file or Hondata hack software ?
