Innovate LC1 wideband setup
AREA876
Re: Innovate LC1 wideband setup
Post by AREA876 »
I will try and then report
AREA876
Post by AREA876 »
Tried connecting LC1 12v source directly to the battery but no change
K20A3 Base Map-181109-002.kdl
AREA876
Post by AREA876 »
Any update on this problem
AREA876
Post by AREA876 »
Any followup information on this issue.
not yet
AREA876
Post by AREA876 »
Any followup info
AREA876
Post by AREA876 »
Anything yet?
We have not been able to reproduce anything here.
AREA876
Post by AREA876 »
Do you have any suggestion as to what I can do to resolve my issue of A/F and analog not matching
You may want to use a different wideband. We recommend using the PSX Devices widebands.
AREA876
Post by AREA876 »
I'm still thinking there is something wrong with the LC1 conversion, using the LC1 conversion this is the result
Notice AN3 is way off from the LC1 reading and the AF is still not matching with AN3
AREA876
Post by AREA876 »
Now when I use a custom conversion this well give a perfect match between AN3 and the LC1 reading but the AF still doesn't match
So my belief is the LC1 conversion is not correct.
I'm trying to figure out if it's my ECU or Kpro that has a problem that's why the AF and the AN3 are NOT matching
AREA876
Post by AREA876 »
Problem solved, the issue was my input wasn't set correctly. My wideband was connected to analog 3 while my wideband input was set to 0 which was my coolant pressure sensor. It's now set to analog 3 and everything is working fine
