air con problem
Re: air con problem
It sounds like there is no problem then.
haRRibo
Re: air con problem
Post by haRRibo »
But where is a problem? In hondata settings?
What to do? I can´t run a car on ECU with disconected Hondat.
Re: air con problem
You need to try this ECU on a different known working vehicle.
haRRibo
Re: air con problem
Post by haRRibo »
OK I will do soon
topsimportgarage
Re: air con problem
Post by topsimportgarage »
haRRibo wrote: Sat Jun 20, 2020 11:39 am OK I will do soon
Any updates on this? Im running into the same problems on my setup. Ive seen a few other post about AC clutch not working with the S300 and nothing concrete it was resolved by either S300 setting or externally.
euroslo24
Re: air con problem
Post by euroslo24 »
running into the same issue
b5 input works correct
a15 output does not ground
if i play with nitrous output with a15 and invert it i can get it to ground the clutch but this is not a permanent solution
Re: air con problem
Most likely it is an issue with the ECU itself as they are over 25 years old and may be damaged.
