Unlocking flashpro from damaged ecu
Re: Unlocking flashpro from damaged ecu
I'm sorry, but this can no longer be unlocked.
KaywayRiley
Post by KaywayRiley »
Spunkster wrote: Thu Dec 16, 2021 11:31 am I'm sorry, but this can no longer be unlocked.
What how i spent $800 on a software for my car for it to go to waste no way that’s not a little bit of money bro i need assistance
KaywayRiley
It shouldn’t be that difficult to unlock
KaywayRiley
My car can’t run without that bro I need that unlocked asap that’s why you’re here right?
KaywayRiley
My car supercharged with 1300 cc injectors i need my flash when i spent my money yall took it willingly I need one small service and that can’t be completed this is ridiculous
KaywayRiley
Hondata wrote: Fri Nov 29, 2019 8:35 am You would need to send us the ECU and FlashPro for unlock.
How did your ECU get damaged? What's the full story?
Mechanic took my ecu out without my consent and tried it in another car the 2 ecus blew in the same spot this is mot my doing only thing i want is my flash off the damaged ecu i just was told what happened
KaywayRiley
KaywayRiley
I had nothing to do with this im just finding out what happened
KaywayRiley
Spunkster wrote: Mon Dec 02, 2019 10:23 am
Hondata wrote: Fri Nov 29, 2019 7:25 pm Please use the 'send feedback to Hondata' function with the FlashPro plugged in and the ignition on.
Have you done this yet?
Spunk can you unlock my flash one more time please I’ll pay for it to get unlocked
KaywayRiley
If you reverse polarize the ECU it has a zener diode to pop an external fuse. Nothing bad happens to it.
What I really wanted was the story from the start, since you have posted about the same problem 6 months ago.
What shop tried to open the ECU? What was their goal in opening the ECU? Did they get the ECU open?
If the ecu is damaged i took it to a store to try get it the burnt piece repaired
KaywayRiley
Flashpro Stuck On Civic Si Hondata Refuses To Help And Unlock It Any Other Suggestions?
I think it’s crazy i bought Hondata years ago and I’ve been supporting them over the years and now I can’t get one simple service done. This is poor customer service I refuse to buy another flashpro and i have one here working perfectly fine My ecu was damaged while my car was at my local mechanic for a rebuild apparently there was a mix up and every car there ecu got burnt on the board. They replaced the ecu but my flash is stuck on the old ecu and Hondata refuses to go into the database and unlock it. $700 it’s a little bit of money so if anyone has any suggestions please help because at this point the car is up for sale because I can’t get the flash on it to tune it it’s supercharged with 1300cc injectors brand new engine rebuild and fx400 clutch kit
This is the third ECU which has burnt in two years. That's more than all the other people with Si FlashPros put together over the last 12 years.
The only way we can unlock the FlashPro is if you send in the dead ECU with the FlashPro. That's not our choice; there is no other way to unlock the FlashPro because we need physical access to do it. But we will not unlock ECUs which has been physically opened in order to prevent fraud.
If your mechanic has damaged three ECUs then I suggest you ask them to cover the cost.
