K24a2 swapped ep3 tune assist
CalibratEd
Re: K24a2 swapped ep3 tune assist
Post by CalibratEd »
Create a normal driving log but make sure to get the car over 3000rpm without going WOT. This helps tune the VTEC transition.
-Ed
Instagram: calibrated.tuning
Burgturdler
Post by Burgturdler »
I tried getting past 3k with most of the shifts as best I could. Thanks.
CalibratEd
Create a normal driving log with a WOT pull.
-Ed
Burgturdler
Car feels a lot more fun already. Thanks.
CalibratEd
Create another WOT log. Make sure to hold the car at 3000rpm for about 5 seconds before you WOT. Make sure to do the run in 3rd gear and on a flat road.
-Ed
Burgturdler
For your review. Thanks.
CalibratEd
Moving to VTC 10 on the VTEC side. Create a normal driving log and make sure you go over 3000rpm as much as you can without going WOT.
-Ed
Burgturdler
Noticed a higher knock count than normal in 3-4-5 gear when going into VTEC.
CalibratEd
I cleaned up some fuel and adjusted timing. Create a WOT pull.
-Ed
Burgturdler
Didn't see any knock events till up top. First WOT didn't feel clean so I did a second one just in case.
CalibratEd
Cleaned up fuel and timing. Create another WOT log. If all is well we can then move to VTC 20 vtec.
-Ed
Burgturdler
For your review. Thank you.
CalibratEd
Create another WOT pull. I added timing up top.
-Ed
Burgturdler
Had a little knock up top with the added timing.
CalibratEd
Reduced timing in the area and fuel looks good. We are moving to VTC20 Vtec. Create a normal driving log.
-Ed
