Re: need help with a tune
Posted: Thu Nov 02, 2023 5:59 pm
Sounds good. I finally had some downtime.
-Ed
-Ed
Finding as follows:
The Air fuels are off in these logs. Be mindful of the IAT and ECT fuel corrections. They are modifying your fueling. Also double check your engine coolant temperature sensor is working properly. The temperature did not change for a few logs which is kind of odd.
I think i turned the car off and then back onCalibratEd wrote: Thu Nov 02, 2023 6:25 pmThe Air fuels are off in these logs. Be mindful of the IAT and ECT fuel corrections. They are modifying your fueling. Also double check your engine coolant temperature sensor is working properly. The temperature did not change for a few logs which is kind of odd.
in log Datalog-231101-004 it looks like the sensors shut off and then come back on. Did the car shut off on you?
- Ed
- Ed
