FlashPro Requests
edwin_2024
Re: FlashPro Requests
Post by edwin_2024 »
Hello, may I ask whether FlashPro managers in different regions can use ECUs of existing models? For example: "US civic Si 2012+ILX 2013+" can you use "Civic 1.5T China 2020 MT BH1" on the Civic in China? Thank you
No you cannot.
edwin_2024
Hello, which project should I write for the serial number 37820-5af-c41. Write this Civil 1.5T China 2020 MT?
Rodrigosantos
Post by Rodrigosantos »
Plase!!! Pops and bangs for Fk2, waiting for years now…! Please!!! I know you can do it!! <3
toadmode
Post by toadmode »
VTC disable added to non-race calibrations please and thank you
OutlawCivic
Post by OutlawCivic »
OutlawCivic wrote: Sun Mar 31, 2024 10:03 am
OutlawCivic wrote: Sun Mar 31, 2024 9:40 am For 2006-2011 Honda Civic, R18A1 motor:
Allow for VTEC to be based on RPM's only, instead of: LOAD CONDITIONS + RPM's.
Also maybe allow users to be able to adjust the parameters/threshold of LOAD CONDITIONS for when the performance cam lobe can be enabled.
Thanks HONDATA!!!!
toadmode
Post by toadmode »
toadmode wrote: Fri Mar 22, 2024 5:23 pm VTC disable added to non-race calibrations please and thank you
Forgot to add, for 2006-2011 Americas Civic Si
KT7788
Post by KT7788 »
Please provide pop and bang funtion for FK2 and FK8
KT7788
Post by KT7788 »
May i check if FK2 is able to have REV match Feature ?
reallyflyguy
Post by reallyflyguy »
2007 TL TypeS
gear ratio adjustment 3.29 vs 3.55
ignition rev limiter to reduce lean conditions
KFactor
Post by KFactor »
Basic Modifications for Accord 2.0T 2018+ AT (Intake, Exhaust, etc.)
AllenZhangFE3
Post by AllenZhangFE3 »
I would really like to know if there is any chance that the ECU with the number 37820-6KA-H03 could get full support from Hondata. Thank you very much.
myuser
Post by myuser »
CarPC Display
Add an argument to the application startup, in order to launch in full screen and exibit the display as the main screen, hide menus and toolbars, to improve visualization in CarPC.
Example: FlashProManager.exe -fullscreen
Solis153
Post by Solis153 »
For a FK8, enable an auto datalog feature that starts datalogging after meeting a user set RPM and Throttle pedal position.
MarcoOtto
Post by MarcoOtto »
Hi,
I would like to see an option when viewing datalogs to view in table format instead of graph format. Example: Using the Graph to pinpoint knocks when the happen can be very tedious. Would it not be great if you could view the log and say view in table format then select the columns you would like to include? In this example I would like to include the Knock number, RPM, EGR, Load, Cylinder no. If we could get this in table format it would be alot easier to pinpoint exactly where they occur and recurrence etc.
