FlashPro Requests
Re: FlashPro Requests
Try to download the datalog as a csv file.
Requesting an expansion to the "Start in R+ Mode" checkbox. Is it possible to add "Start in Comfort Mode"?
Another user started the discussion a few years ago. viewtopic.php?p=139663#p139663
Missing out the FK2 pop & Bang - please bring back .
Convert multiple datalogs at once.
Option to convert a datalog file or files, to csv, in this way it is possible to convert the previous saved datalogs.
I would like to datalog the speed beyond 255km/h. Since I read somewhere that the ECU stops reading the VSS at this speed, Is it possible to program a datalog channel doing some math using the gear ratio and engine speed to calculate the speed?
Thanks in advance
Thanks in advance
No, this is the mathematical limit of the ECU.
Is not possible to Hondata make some code injection to the Hondata datalog adding this math calculation in a separate speed channel based in the data acquired from the ECU with rpm and gear ratio data?
I'm not a software developer and have no clue about the difficulty of what I'm asking, sorry if my idea don't make sense.
Hi guys, is it possible to Provide ignition Retard Table for FK2 ( like Integra Type S DE5 ) ?
Display FP Mini's LED status on FlashPro Manager/Apps
For the FlashPro Mini, is there any way to get a remote display function within FlashPro manager and/or the mobile and dash apps?
The status lights of the FlashPro Mini are not easily seen from the driver's seat, and currently the only way to tell if the FP mini is hardware logging is to stop the car and get down into the driver's footwell to see the status of the blue log led.
If there was some way to view the logging status from within FlashPro manager (laptop attached via USB) or on the dash app (10th gen civics) and/or iphone/android FlashPro app, this would be a very helpful improvement.
and if we could remotely start/stop the hardware datalogging function as well, that would score huge bonus points, but I'm not sure if that would be possible.
thanks as always!
thanks as always!
ECT2 default value when disabled
Scenario:
Civic 2019 1.5 CVT,
Hondata Flashpro,
ECT2 Disabled cause ethanol it is connected to this pin,
Ethanol Enabled
Issue:
Intake Cam and Ex Cam WOT VTC tables changes are not being reflected, looks like it is not using those VTC tables cause ECT2 it is disabled and It's default value it is 32F.
Feature Request:
Looking for the possibility to override the ECT2 default value to higher than 60C when it's disabled, that way any modification in WOT VTC tables will be reflected as it should, because in this scenario any change to WOT VTC tables are not being reflected
Or any fix to this issue with this scenario
I Hope you can help ! Thanks !
Regards
Civic 2019 1.5 CVT,
Hondata Flashpro,
Ethanol Enabled
Issue:
Feature Request:
Regards
Wishlist
- FK2 to Provide ignition Retard Table ( like Integra Type S DE5 )
- FK2 to provide downshift Rev match like FK8
thank you
thank you
I would like to request 16-19 china version of MT civic's (5AF-H1x) supporting 4bar sensor
AllenZhangFE3
Wishlist
1. 2022 civic 1.5T(non-Si) add throttle quick modification;
2. 2022 civic 1.5T(non-Si) add 4bar sensor support
Model:2022 civic 1.5T sedan
ECU:6KA-H03
thank you
ECU:6KA-H03
thank you
Is it possible to add idle stop enable/disable for the 2019-2025 RDX? If so, I would like to request for that feature to be added.
Wishlist
1. hondata 4 bar sensor supporting
2. Canflex supporting
