FlashPro Requests
AllenZhangFE3
Re: FlashPro Requests
Post by AllenZhangFE3 »
Wishlist
1. 2022 civic 1.5T(non-Si) add boost scramble option;
2. 2022 civic 1.5T(non-Si) add throttle quick modification;
3. 2022 civic 1.5T(non-Si) add 4bar sensor support
Model:2022 civic 1.5T sedan
ECU:6KA-H03
thank you
KT7788
Post by KT7788 »
FK2 - downshift Rev Match please
AllenZhangFE3
Re: FlashProManager 4.5.1
Thank you very much to Hondata for continuing to bring updates to the Chinese community. We look forward to future support for the 4-bar MAP sensor on 2022+ 1.5T models in China.
hktwinsen
Post by hktwinsen »
Wishlist
16-19 china version of MT civic's (5AF-H1x)
1. hondata 4 bar sensor supporting
2. Canflex supporting
AndyLis
Post by AndyLis »
Hi Hondata team,
I’d like to request the ability to manually edit gear ratios in the calibration for the 1st generation Acura TSX (using FlashPro). After swapping to a closer-ratio gear set (1st–5th), cruise control no longer functions properly in 4th and 5th gears. I believe this is due to the ECU detecting unexpected RPM-to-speed relationships.
Being able to input the correct gear ratios could help restore cruise control functionality in such cases. It’s especially important for those of us who drive long distances and rely heavily on cruise control.
Thanks for considering this!
scofield
Post by scofield »
2017+ CRV wish list :
Cooling fan control
ctr_uk
Post by ctr_uk »
Fn2 live map switching its available with other tools and seems a shame not to be able to do it with hondata. I love my flashpro, please make it perfect.
deafy03
Post by deafy03 »
07-08 TSX gear ratio adjustment. Please add this, as it is pretty necessary in order to run BBG. When I'm in 2nd gear, flashpro shows it being in 3rd, 3rd gear shows 4th, etc. Pretty sure this is also preventing cruise control operation. Could we just load up the 8th gen civic si map and adjust the gearing that way since that feature is available on that map?
FK8_Hoonigan
Post by FK8_Hoonigan »
Good morning team
See attached image for render of expected request.
Could FK8/FL5/DE5 vehicles (or all MED17 for that matter) get something like AirC Limit by ECT added?
Like back in the day when VTEC wouldn't engage until engine was warmed up.
For the reliability and longevity of engines, it would be a great safety feature added to ensure the engine is at operating temp and all internal clearances are adequate and the oil is also at temp. Winter is coming and this would be greatly beneficial during the cold months.
GARIX Tuning
2021 R-39464
https://dot.cards/garix
AllenZhangFE3
Re: FlashProManager 4.5.9
2022 civic 1.5T(non-Si) still waitting for 4bar sensor support
it is really key point for my G25-550 turbo, please consider the requirement
ECU:6KA-H03
Trawa
Post by Trawa »
Would it be possible to add rev hang delete (overrun cutoff delay) to the Accord Euro 2009+? It's already an option for the 2009+ TSX but the Euro doesn't have it.
AllenZhangFE3
One version after another — full of expectations, then disappointment.
Of course, we’ll keep waiting for Hondata’s work… sigh.
4bar sensor support please
ECU:6KA-H03
hktwinsen
Post by hktwinsen »
Wishlist again...and again
16-17 china version of MT civic's (5AF-H1x)
KT7788
Post by KT7788 »
FK2 - Requests
- POP and Bang
- Throttle blipper active only in (Clutch in + Brake depress ) Example : PIVOT BLP / https://pivotjp.com/product/blp/blp-e.html
Thank you
Fk2*From*France
Post by Fk2*From*France »
Wish list : FK2 Request > Fk2 tables and mod"s likes FK8 pleeaaaaaaaaaaaaaasssee
