SManager software requests
Johnny_9
Idle Up - ACSW on/off - customizable INJ & IGN
Post by Johnny_9 »
http://ecomodder.com/forum/showthread.p ... d-967.html
Uploaded with ImageShack.us
Either have a separate I.A.C.V. duty cycle for ACSW=on
or
Be able to customise the INJ and IGN delta when ACSW=on
Air Con RPM Increment - This value is added to the �Target RPM�. It is done to handle the extra load when the air con is turned on. It is taken away again when the air con is turned off.
Air Con Duty Cycle Increment - This value is added to the �Start Duty Cycle'. It is done to handle the extra load when the air con is turned on. It is taken away again when the air con is turned off.
Really like to hear HONDATA feedback on this.
stikerguy
Re: SManager software requests
Post by stikerguy »
I would like an actual antilag not so much what we have as of now! I have been having a little bit of trouble building boost and never before had any problems doing so.
FreshDA9
Post by FreshDA9 »
Hows about a pressure vs duty cycle table based on map sensor selection. under boost control parameters. having more cells will allow better adjusting for desired psi.
EFI-101 & Advanced Certified*
HeitorVTiBR
Post by HeitorVTiBR »
put to select only ignition rev limit ... and place to select what kind of RPM Limiter Launch launch control (ignition, fuel + ignition, or fuel only)
Ignition only would be very bad as it would continue to dump fuel and wash the bores and could even cause hydrolock.
FreshDA9
Post by FreshDA9 »
FreshDA9 wrote:Hows about a pressure vs duty cycle table based on map sensor selection. under boost control parameters. having more cells will allow better resolution for desired psi.
This ^ plus live logging in the battery offset tables will help will help a lot!
Manny1987
Post by Manny1987 »
Any chance for making a drop down menu for commonly used Wideband's such as PLX's etc. Thatway its all preset minus the minor adjustments that may need to be made on the offset.
Johnny_9
Post by Johnny_9 »
can u put an email alert for new Smgr on the forum/website
There is a RSS feed on the downloads page, plus we also have a forum post with the changes.
Johnny_9
Post by Johnny_9 »
Hondata wrote:There is a RSS feed on the downloads page, plus we also have a forum post with the changes.
Couldn't see it; could you kindly indicate where is RSS sign up; also would like it for S300 only.
turbo-2nr
Post by turbo-2nr »
it would be nice to have some of the new things like the kpro lll
mainly 8 additional analog inputs for datalogging
but all of them would be nice
Twice the on board datalogging memory
- Three times the programming speed
- Anti-theft security enhancements
- On board calibration storage
and we need a boost by speed off of rear abs sensor its holding a lot of cars back on s300
i just keep seeing kpro get upgraded with cool stuff and it seems like no one cares about the b,d,h,f series guys any more i would hate to have to go to aem,proefi,motec just the get the features we need when i think the s300 is capable
cloviskilla
Post by cloviskilla »
throttle tip out trim?? neptune has it... and please add adjustable launch control, soft to hard reps...like aem
AREA876
Post by AREA876 »
I would love to see Boost Control (PWM) enable through output A17 (IAB) for a JDM ECU
cloviskilla wrote:throttle tip out trim??
Do you mean tip in trim? It is under 'Fuel Trim'.
cloviskilla wrote:adjustable launch control, soft to hard reps...like aem
Under 'Launch Control', change the 'Fuel & Ignition Settings' so that the Activation RPM is just below the launch rpm (try somewhere between 0-100 rpm), and set the ignition timing to -40.
cloviskilla
oh so the closer the rpms in the values the softer the reps is????
