FlashPro V1.5.6
angelf1974
Re: FlashPro V1.5.6 (beta)
Post by angelf1974 »
Please, add the possibility to change the gear ratios of the 07 TSX.
Honda Accord CL9 (Spain)
VitViper
Post by VitViper »
I derked.
mucter
Post by mucter »
File naming for datalogs in the flashpro has been screwed up since the beginning of the 1.5.x branch. Names don't save in the flashpro when you change them, and then when you go to save a file out of the flashpro, the filename in the dialog is all wonky.
Zoro2006
Re: FlashPro V1.5.6
Post by Zoro2006 »
There is problems with Production release V1.5.6 and TSX calibrations. For example if I open any build in TSX calibration (as example TSX-07-8-DW600) save it to different folder and later open - error appears. Tried to do the same with older Beta V1.5.6 and there is no such errors.
Known as Vaikis_
sass
Re: FlashPro V1.5.6
Post by sass »
I have the same problem
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
BWelbourn
Re: FlashPro V1.5.6
Post by BWelbourn »
I just updated to FP Manager version 1.5.6 (production release: July 2, 2013) from the production release version 1.4.5. My datalogs from the first ECU flash under version 1.5.6 have K.Level recordings all at 98%. K.Level has never stayed at a constant level in my dataloging prior to version 1.5.6. Is there something wrong with the K.Level under FP Manager 1.5.6?
Thanks.
2012 Civic Si
FP-2012Si-110021
FP Manager Ver. 1.5.6
Windows 7 Home Premium
Re: FlashPro V1.5.6
Zoro2006: This is to prevent manual transmission calibrations from being loaded into automatic transmission ECUs.
BWelbourn: You need to upload to the ECU again with 1.5.6
BWelbourn
Re: FlashPro V1.5.6
Post by BWelbourn »
Hondata wrote: BWelbourn: You need to upload to the ECU again with 1.5.6
Hondata, Thanks for the quick reply. I uploaded the calibration to the ECU for the second time under 1.5.6 (note: I unplugged FlashPro from the vehicle's OBDII port between the first and second ECU flash under 1.5.6) and still have K.Level "flatlined" at 98%.
Here is a copy of the calibration file and a datalog from the second ECU flash under 1.5.6.
Thanks.
2012 Civic Si
FP-2012Si-110021
test_v1.5.6.fpcal
test_v1.5.6.fpdl
sass
Re: FlashPro V1.5.6
Post by sass »
Hondata wrote:Zoro2006: This is to prevent manual transmission calibrations from being loaded into automatic transmission ECUs.
"automatic gear, manual transmission is not the problem, because when i load my calibration in PC the error appears. There were no such errors in previous 1.4.5 version"
Known as Sniper
Re: FlashPro V1.5.6
This message is just ot inform you that you are using a shared calibration. There is nothing wrong with it. If you do not want the masseage to appear, plug in the FlashPro prior to loading the calibratoin in the FlashPRo manager.
speedhacks
Re: FlashPro V1.5.6
Post by speedhacks »
· [Civic Si] Added light control features for knock control and traction control
I am on an FG/FA 2007+ Civic SI calibration, nowhere is 'light control features' for knock enabled...
Re: FlashPro V1.5.6
You must be using a race calibration whcih doe snot have these ooptions. You will have to use an AFM based calibration which can be tuned via MAP.
speedhacks
Re: FlashPro V1.5.6
Spunkster wrote:You must be using a race calibration whcih doe snot have these ooptions. You will have to use an AFM based calibration which can be tuned via MAP.
Ah that would explain it.
Will I need to have an airflow sensor plugged in for this? I do not have the MAF anymore as this is a turbocharged engine so I am not sure I can use an AFM based calibration.
I'm a little wet behind the ears with this.
speedhacks
Re: FlashPro V1.5.6
Will I need to have an airflow sensor plugged in for this? I do not have the AFM anymore as this is a turbocharged engine so I am not sure I can use an AFM based calibration.
I answered my own question. Heh - thank you!
soxfan143
Re: FlashPro V1.5.6
Post by soxfan143 »
On AFM Hybrid maps boost control duty will not datalog. It stays at 0 all the time. Any idea why?
