fuel level gauge
R-12914
Re: fuel level gauge
Post by R-12914 »
@Hondata: At this time, do you work on a solution for this issue?
Please let us know!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Any news?
If you are working for a solution keep us up to date please.
We're looking at this. It is going to take more than 2 days, so be patient.
neoarks
Post by neoarks »
Thanks hondata
Does someone has a (short) datalog with stock fuel injectors at a steady speed where we know the fuel consumption?
eg at 90 kph there should be published figures for the FN2 (perhaps 7 l/100km at that speed?)
typer86
Post by typer86 »
Unfortunately I can not provide a Datalog with this setup which you have requested. :-( Maybe you can compare it with the U.S. Civic SI car?
In advance thank you very much for your support and to find a solution.
Edit:
Please check the website here:
http://flashprotuning.com/infamous-edyno/requests
I hope you can use the attached datalog.
3rdgearpullgroupN01.fpdl
2008 Euro Type-R Stock with Group N map
Target AFR
• 13.5
Vehicle Details
• 5.062 Final Drive
• FN2
• Stock weight (2792lb/1267kg)
• Civic Type-R
R-12914
Post by R-12914 »
I think this will not help Hondata?!
Hondata need exactly one FN2 with stock 310cc injectors and the precisely calculated fuel consumption, as they have written!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Hmm Ok, so I can not provide the requested datalog. Hondata I hope it is possible for you to find the solution without the datalog from us.
R-12914
Post by R-12914 »
typer86 wrote:Hmm Ok, so I can not provide the requested datalog. Hondata I hope it is possible for you to find the solution without the datalog from us.
I have put it into the Civinfo Forum:
http://www.civinfo.com/forum/type-r/197 ... ost2843114
I am waiting for help of them! ;)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Can someone test this change?
Download FlashProManager 2.2.1
Under Fuel -> Fuel Economy there is new setting for the injector size 'Injector Flow for Dash'.
There also are two extra datalogging sensors - fuel economy and fuel used. Both use the 'Injector flow for fuel economy calculation' setting, but should allow you to more quickly set the right size for correct fuel economy readings using the second 'Injector flow for dash' setting.
R-12914
Post by R-12914 »
Hondata wrote:Can someone test this change?
Download FlashProManager 2.2.0
Thanks!
If i chance the value in my MAF-Cal, the value is accepted, if i change the value in my MAP-Cal, the value switch back to "0"!
Can you fix this bug?
To understand:
If i use 750cc with supercharger, than i must but in the value "750" in "Injector flow for dash"?
What value i must but in in "Injector flow for fuel economy calc", also "750"?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
It is not supported in the race calibration. For the injector size, make a large change, and see if it has any effect. eg 800cc
R-12914
Post by R-12914 »
Hondata wrote:It is not supported in the race calibration. For the injector size, make a large change, and see if it has any effect. eg 800cc
Now i have test it and the results are this:
With 800cc Injector size as follows:
Results with 800cc Injector size:
and
With 1200cc Injector size as follows:
Results with 1200cc Injector size:
If i put in 750cc (my RC750cc) size, i think the values are correct.
I will test it again with a full tank fuel and 750cc values!
BTW:
In the Forum Overview under "European FN2 Civic Type R" its written -> "FlashPro questions & answers specific to the FN2 "Japanese" Civic Type R". Correctly it should written "FlashPro questions & answers specific to the FN2 "European " Civic Type R".
Please fix it! ;)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
neoarks
Post by neoarks »
Looks fine!!!!!
Not available for race calibration :(
Thanks for the testing. Because of the way different injectors are rated (voltage, pressure) the correct number for RC750s is probably around 800-850cc.
BTW now there are injectors with better spray patterns than the RC550, RC650 & RC750 injectors. On my car fuel economy improved and and spark plug fouling disappeared when I switched from RC750 to DW800.
