Injector Driver Box
SPOOLIN
Re: Injector Driver Box
Post by SPOOLIN »
FYI you have not made this version public in the downloads section..................................
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
I could use a digital version of the wiring chart for what wire color does what on the unit. I lost mine and need it.
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
Bug 2: Injector Dead times do not save when selecting pre-loaded injector dead times in the staged injector area (and obviously manually entered ones)
2.5.3.0
www.MSSRACING.com
9.29 | 6.20 | 167
Ok, thanks for the report. We'll fix this today.
Update: Fixed, Download here
SPOOLIN
Post by SPOOLIN »
thanks.!
www.MSSRACING.com
9.29 | 6.20 | 167
welen78
Post by welen78 »
If I use this with any other ECU.. Does the staged injectors fire directly the duty cykel after the driver gets the trigger signal or is there something else going on?
I'm not sure what you're trying to ask.
welen78
Post by welen78 »
How does the injector driver work? When it gets activated does that make the second set of injectors to start at the next injector dutycykel or is there some function in the s300/kpro software that triggers the driver and then delys the starting point of the second set injectors by a fixed value the driver "knows" or something?
If the injector driver start the second set directly by the next injector dutycykel I belive I can use it with other ecu:s then Hondata.
When the injector driver activation input is grounded then the outputs will fire exactly the same as the inputs.
Are you going to use it as staged or slaved?
welen78
Post by welen78 »
Thanks.
I plan to use it staged.
