FlashProManager v2.4.9 Beta
Re: FlashProManager v2.4.6 Beta
Reflash tachometer progress indicator: This do not work on FN2!
Ok, found that problem and will do a release to fix later today.
vtecrasr
Post by vtecrasr »
everything works! thanks again
15 civic si, bolt on's/tuned by cartermotorsports
BEKA-BEKA
Post by BEKA-BEKA »
Is it possible to have these ign and fuel adjustment at launch rpm and full throttle options on the R18 2006-2011 and Is there a possibility to have them available in the nearest future? :p
m1ll3rlyt3
Post by m1ll3rlyt3 »
All the features work for me except the launch control isn't actually working. I can set it and adjust it but it still revs past where I set it.
Sorry. I have a 2014 fg4 and the cal I'm using is the prl short ram that comes with the software.
2014 FG4
kenleung8
Post by kenleung8 »
Thanks! Everything works with v2.4.8 for my 2015 Civic Si FB6.
m1ll3rlyt3: I don't have a crystal ball. You'll have to at least tell me what ECU your vehicle has. Then post the results of the troubleshooting on the previous page, and your calibration.
m1ll3rlyt3
2014 FG4
R-12914
Post by R-12914 »
R-12914 wrote:In additional to the tachometer-upload indicator if we uploading a map, can you make a feature like this:
https://www.youtube.com/watch?v=jJ465JikHvc
I mean only a fast (faster as in the video) turn up and down the rev counter, the coolant temperature gauge and fuel gauge when the ignition switch on!
Many cars have this feature from factory like a gauge check up!
It would be nice if you could define an option here, where we could enable or disable this feature with a hook in the software!
Is that possible?
Thank you!
Hondata, is this possible on a FN2?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
GaryBar
Post by GaryBar »
m1ll3rlyt3 wrote:All the features work for me except the launch control isn't actually working. I can set it and adjust it but it still revs past where I set it.
is there a value by ur launch disengage speed? Mine was on 0 and it did the same as what urs is doin i then set it to 3mph n boom it worked
R-12914
Post by R-12914 »
Hondata, since the Version 2.4.7.0, the launch control no longer works on my FN2!
Hondata wrote:
Here's a test procedure to follow:
1. Set launch rpm to 3000 rpm. Set full throttle shift to 4000 rpm and 1% throttle. Upload.
4. Press the 'cancel' switch and confirm that the tach does nothing. Press in the clutch as well as the 'cancel' switch and confirm the tach shows 3000 rpm.
The set rpms to show with the "cancel" switch still works, but if i rev up the engine, it does not work like before!
Whether clutch depressed or not or cruise main switch on or off!
In any case, the engine revs up over the launch rpm set!
Please can you fix this issue like before?
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
m1ll3rlyt3
I'll try that too along with what hondata said with the test procedure
2014 FG4
GaryBar
Post by GaryBar »
No probs hope u sorted
vtecrasr
Post by vtecrasr »
make sure you set the disengage speed to 3 mph or whatever above 0mph. I first did that and was like well the cruise buttons work but it would rev past whatever I set the launch at. and then realized I never changed the speed disengage
R-12914
Post by R-12914 »
This works fine, now on FN2!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
