Installing Hondata Mobile on your 10th gen Civic radio/navi
hedgehog9780
Re: Installing Hondata Mobile on your 10th gen Civic radio/navi
Post by hedgehog9780 »
Because I read in the instruction, that I have to pair with the Flash Pro. (viewtopic.php?f=50&t=21099 Section E. Linking Flash Pro.
I thought, that I have to use a laptop or pc via Bluetooth. Otherwise I stuck at section E.
What version of the Hondata Dash App are you using?
hedgehog9780
I have to check it. (Unfortunately this beautifull cat isn't mine). I visit my friend and I'll check it. If it is not the latest, how can we update? Thank you in advance.
First we need to know what version you are trying to use.
hedgehog9780
Hello,
I have taken a short photo from vesrion. This is what you mentioned? (see attached photo)
That is not the version of the Hondata dash App.
hedgehog9780
Hi,
Sorry for the late response, but I get the photo from my friend, but I forgot to upload it. Below you can find.
If it is not what you are asking, where can I find it.
He mentioned me, that he did a factory reset. Since it, the HU drop the bluetooth signal. How can we correct it?
I highly appreciate you support.
That is not the version of the Hondata dash app. You must open the dash app and go to the options/settings to see the version.
hedgehog9780
Hi,
My Friend is here. I see, we try to use the Hondata dash app 1.5.4.1.apk
hedgehog9780
As I see, Honda modul (ODB2) is needed for it and not working without it.
Where can we buy it?
You can purchase the FlashPro from one of our dealers or our website.
LexieGrayRose_FK8
Post by LexieGrayRose_FK8 »
Hey Hondata ,
Is version 1.5 still the latest version or has 1.6 come out ?
Is there a way to make the fuel pump duty cycle gauge needle move on the update ?
Right now I have 1.5 version ans to monitor Fuel duty % the number moves but the gauge needle stays in the middle position.
Any fix for this or no?
mzbizness
Post by mzbizness »
I successfully uploaded the Honda hack. There is one issue I cannot Figure out. My usb won’t stay on device (in developer options) it automatically switches back to host when I exit out of the menu. This causes the CarPlay not to work.2021 Honda crv
Fkay8
Post by Fkay8 »
I don't know if this is the right post to ask this but I'm sorry if wrong.
Since the Honda LogR app on the 2021 FK8 have the oil pressure and temperature values, at least on the EDM market, is not possible to had this values on hondata dash?
Thanks in advance
