Hondata Mobile APK 1.5 (Android) for Dash
Tpain1984
Re: Hondata Mobile APK 1.5 (Android) for Dash
Post by Tpain1984 »
2019 civic type r
Honda hack with mobile app
Bluetooth is connecting on headunit and the app is pairing it but it crashes immediately everytime it connects with the dash app.. ive used 1.5 & the 1.5.4 updates... any help?
Ive uninstalled, re installed, rebooted, etc
Are you saying the head unit is crashing?
itsameduh
Post by itsameduh »
Is it possible to install hondata apk on '19 crv? I've got the hondahack installed. Flashpro paired via Bluetooth to headunit no problem. I've formatted to exfat and downloaded apk from flashpro software and from apkpure, but headunit doesn't see it. Tried both usb slots in console. Can't download from headunit on playstore; it says not compatible with this version. Idk what else to do.
I believe it will only work on the Civics.
itsameduh
Post by itsameduh »
Spunkster wrote: Tue Jun 23, 2020 9:02 am I believe it will only work on the Civics.
Ok, thanks for the heads up.
itsameduh
Post by itsameduh »
From Hondata mobile for inquiry of the 5th gen CR-V compatibility.
"There are no plans of adding support for Honda head units using Honda hack because the head unit does not have the minimum required processing power to run the app."
I should've done more research before spending $25 on hondahack and $8 on Hondata Mobile. Hopefully this helps someone else!
Deebo
Post by Deebo »
Good day, how can i get the dash app to work on a APLPINE ILX-W650 digital receiver ?
Please !
