Page 4 of 4
Re: K24a2 swap in 8th gen
Posted: Thu Mar 31, 2022 1:03 pm
by Rocko08
Just got it just had to clean it up so started over at 0 on logs
Posted: Thu Mar 31, 2022 7:03 pm
by EFICU
Sorry I missed those earlier posts. This datalog looks great. We will do one final one with locked cam angles, then we blend it out and see how it feels with all the cam angle mapping set. This one will be the 40* cam angle with vtec at 4500. Take it for a spin when you can, all we really need is a clean third gear WOT pull, so a ten minute datalog is fine. We're almost there, thanks for being patient.
Rocko08.SD.Rev06 (40Cam)(Vtec4500).fpcal
Posted: Fri Apr 01, 2022 9:45 am
by Rocko08
Posted: Fri Apr 01, 2022 10:23 am
by EFICU
Okay it looks really good. I've gone in and blended out all the cam angle mapping stuff. Take this one for a spin when you can and see what you think. It will take a revision or two to smooth out all the fuel, but it's plenty safe to have some fun with it and see how it runs. Vtec looks happiest to start at 4500, so see what you think there, we can move it up or down a bit to test as well. But try this file, shoot for twenty minutes and at least one third gear WOT pull. Other than, drive it however you want and see what you think.
Rocko08.SD.Rev07 (Blended)(Vtec4500).fpcal
Posted: Fri Apr 01, 2022 10:57 am
by Rocko08
Sounds good I'll throw it in an send log back
Posted: Fri Apr 01, 2022 2:05 pm
by Rocko08
Posted: Fri Apr 01, 2022 3:59 pm
by EFICU
Looks really good, I made a couple small fuel adjustments and some ignition changes for the knock. Other than that it was pretty much there, take this one for a spin when you can. No rush, it's 99% there, just splitting hairs at this point.
Rocko08.SD.Rev08 (Blended)(Vtec4500).fpcal
Posted: Fri Apr 01, 2022 6:55 pm
by Rocko08
Okay ill get it in there this weekend ..thank you for everything..what do I owe you for getting this thing dialed in ..
Posted: Fri Apr 01, 2022 7:57 pm
by EFICU
Sounds good. You're welcome!
I leave all the money up to you guys right now. But I'll PM you my email address.
