Need some serious Help, please!!
boricua
Post by boricua »
early morning bump, finding a ride to work. Guess everyone fell asleep last night still hiping for answers. thanks guys
boricua
Post by boricua »
SPUNK... WHERE YOU AT!! BEN WHERE'D YOU GO? LAZIE HELLLOOO.
Martian
Post by Martian »
Your ignition map is all over the place, and it looks like there may be a vacuum leak. 14* with 0%TPS, throws up flags for me. It could also be the IACV, but I doubt it would make things that erratic.
thank you, thank you, I'm here all week
boricua
Post by boricua »
i'll double check my grounds again today, and clean aout my iacv, and also double check my tps. something's gotta give.
I finally spoke with mase yesterday over im at honda-tech but he hasn't gottten back to me he's out of the country..... any more input guys..........
boricua
Post by boricua »
checked all everything is good, also switched out the map sensor for another stock i got at the yard. I need some more advise, 1 thing i did notice when doublechecking everything was that my crank pulley at TDC is not lining up with the timing belt cover mark? could this be the culprit? cam gears are 1/2 tooth off....
Martian
Post by Martian »
You are not helping matters by switching parts, and not doing simple diagnosis. Have you calibrated your TPS before at all? Have you vacuum tested your intake at all? Do you understand how the ECU works to adjust fuel and timing?
If you answer no to any of those questions, you NEED to take it to someone with far more ability than yourself. Fact is, you are digging a deeper hole for yourself.
boricua
Post by boricua »
Martian i completely understand, tps is calibrated to .47 at idle and 6.6 WOT.
Intake is vaccum tested with spray bottle with soapy water.
I don't really understand how the ECU works to adjust fuel and timing?
So it has nothing to do with the hondata tuning? it's basically some sensor not throwing a code letting me kow what it is?
Question, can i still drive my car like this after viewing the datalog files?
RedR
Post by RedR »
6.6 at wot? should be in the 4.5 range
boricua
Post by boricua »
Their's no more adjustment it's all the way to one side and tightened...
boricua
Post by boricua »
cmon people wtf.....let me know something. spunkster can you chime in
You need to try a new TPS, or perhaps your throttle body is bad and needs to be replaced.
boricua
Post by boricua »
rodger that, let me see what i can do. thanks
boricua
Post by boricua »
Spunkster wrote:You need to try a new TPS, or perhaps your throttle body is bad and needs to be replaced.
SPUNKSTER U ARE DA MAN!! IT WAS THE TPS!!
Can someone please tell me when setting it the way the service manual tells you to is wrong, i mean i had it at 0.48 at idle and 6.8 at wot adjusted all the way to one side as per the multimeter........ when i moved it to the middle and hondata reading 5 volts at idle the car fixed itself. I don't get it.
inteGReddy
Post by inteGReddy »
boricua wrote:Can someone please tell me when setting it the way the service manual tells you to is wrong, i mean i had it at 0.48 at idle and 6.8 at wot adjusted all the way to one side as per the multimeter........ when i moved it to the middle and hondata reading 5 volts at idle the car fixed itself. I don't get it.
Most service manuals are useless when your modding a car.
Why did you not simply calibrate the tps in hondata?
When starting a new calibration one of the first things I do is calibrate the max and mins of my TPS.
