KPro / KManager requests
Re: KPro / KManager requests
Problem is that if you have latest version it cannot be downgraded.
Exactly. No matter how many times we tell people not to downgrade software versions they still do. We're the creators of the hardware, firmware and software; you'd think our instructions would carry some weight.
Knox
Post by Knox »
Adjustable cold start rev control like s300.
sass
Post by sass »
do you plan to make air temp compensation for k-pro boost
Boost Control Parameters
The boost pressure for a given duty cycle will vary with ambient air temperature, with increased pressure with cooler air and less pressure with hotter air. This table allows you to adjust the duty cycle based on intake air temperature. The compensation is applied to both a fixed duty cycle and duty cycle by rpm & gear.
k24a2 stock
18C
44C
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
akep
Post by akep »
i've been wanting to have Ctrl+S for Save As... added to Kmanager for a long long time. I like to save my changes often so I can go back easily or flip flop around when troubleshooting. Also the less I have to use the trackpad to point and click for things the better. or even better, if there could be a shortcut for saving but it adds a revision number automatically to the currently opened .kal. for instance if i had "Mike K20.kal" I could hit a keyboard shortcut like Ctrl+Shift+S and it would just save "Mike K20 001.kal" then "Mike K20 002.kal" or whatever fashion/wildcard could be manually inputted besides "001, 002" like fewer or more numbers or the date.
MPG estimator while live tuning is enabled?
TJAPZ0RRO
Post by TJAPZ0RRO »
Ignition retard activated by clutch switch input : )
Edit: You don't want to retard with every shift, only for full throttle shift ..
So, ignition retard after clutch switch input AND tps 90%+
-TJAP
sass
Post by sass »
hondata
could you tune tracktion(TC) by gears: i'd like it to activate on 1st and 2nd gears, but not on 3, 4, 5th.
kind of idea
Known as Sniper
sass
Post by sass »
second variant
Known as Sniper
Max vehicle speed would be easier, but would just maximum gear be better still?
Knox
Post by Knox »
Hondata wrote:Max vehicle speed would be easier, but would just maximum gear be better still?
Is it possible to add these features?
Rev limit by gear and adjustable idle rpm by ect like s300.
sass
Post by sass »
Yes
Any variant
Gear-speed
Known as Sniper
Honda
Post by Honda »
Knox wrote:ignition cut, if possible.
thanks.
+1
NtegraDryvr
Post by NtegraDryvr »
2 requests
1.
I am desperately needing a delay function added to the Nitrous fuel & ign tables that I am using for water methanol injection.
I spray 45GPH (2835cc/min) worth of 80% methanol to water in 2 stages (20gph then 25gph). What is happening is that the computer removes fuel before the WM makes it to the motor and the car has a huge lean spike and bogs for a second then takes off like a huge shot of nitrous. This is due to 2000 units of fuel being removed from the injectors when the nitrous controls are activated but before the methanol makes it to the motor.
2.
Also it would be very helpful to add the option for activation based on gear since we don't have closed loop boost control. I would rather closed loop boost control be added, but this would solve another issue for me as well if this could be added. One day my boost levels in X gear are much higher or much lower and this effects activation of my 2nd stage.
If these issues can be fixed soon I will be purchasing a traction control unit as well, if not I'll be going AEM infinity to get these features.
Thanks!
Knox
Post by Knox »
cold start idle rpm ect compensation, rev limit by gear, ignition cut.
D-Rob
Post by D-Rob »
I pop in here once a year and request an IAT vs PWM duty compensation table.
Thanks!
contectr
Post by contectr »
Closed loop boost control!! :-)
Honda Ep3 stock k20a2 jrsc
