FlashProManager v2.2.8
VitViper
Re: FlashProManager v2.0.9
Post by VitViper »
Thank you, will be trying the update shortly and will let you know.
VitViper
Post by VitViper »
TSX's working pro now.
Can we get the ECT cranking compensation tables exposed on the 2012+ Civic Si's? I have some E85 cars that need a little bit more love and the crank comp in the software is a little lacking at the moment...
DomGSR-T
Re: FlashProManager v2.1.0
Post by DomGSR-T »
Rev hang issues was fixed on rev 1.7.0 for the Kseries guys... I wonder when we will get this fix for the TL ecu?
R-12914
Post by R-12914 »
Hondata, what are you doing?
The 2.2.0.0 not existing!
Edit:
Now it is OK! :)
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
RiC
Post by RiC »
Having problems downloading the v2.1.0 it's says File Corrupted...
Keep trying. I've reset our webserver and contacted our host company.
RiC
Post by RiC »
Keep getting error...
Just download directly from the downloads section of the website.
RiC
Post by RiC »
Have downloaded from Hondata Downloads v2.1.0 like 25 files and all says corrupted :(
RiC
Post by RiC »
Weird thing is that one has the 135MB size that the file should be, all finished download at less size and says corrupted, have tried on a friends laptop and same error...
RiC
Post by RiC »
Does anyone has the file to share?
refresh the downloads page and it should allow you to download now.
hunterspb
Post by hunterspb »
Flashpro died after upgrading 1.9.3.0 -> 2.1.0.0
i've update my flashpro from 1.9.3.0 to 2.1.0.0, Upload new calibration to flashpro and turn off flashpro from USB.
1) nothing happends after connection to USB (all lamps are off)
2) if i connect flashpro to car all lamps on flashpro are off, but in car dash i see "SCS Service" (may be cose i've got one srs error)
Flashpro serial number:
FP-TSX-US-90134
Did you use any other Hondata products on the same computer?
mabo
Post by mabo »
hunterspb wrote:Flashpro died after upgrading 1.9.3.0 -> 2.1.0.0
FP-TSX-US-90134
Hondata recently introduced quick support option, can be found in help menu. I dont know if its beta or under development now. But it worked for me. Its based on remote desktop technology. I used it and support team solved a problem with FP drivers i had after recent FP manager update. I could have same problem but my flashpro survived. FW update stalled at 20-30% and then i wasnt able to recognize it with PC. Maybe it was irregular port glitch, driver glitch, maybe i had to do that with external power attached to my laptop, dunno for shure. You can try this quick support option, im shure Hondata will help you like they helped me.
