Running Hondata Mobile on your radio/navi
Civic 2016+ 1.5 Turbo
regice202
Re: Running Hondata Mobile on your radio/navi
Post by regice202 »
Spunkster wrote: Mon Jan 17, 2022 10:19 am The Dash App is only supported on OEM Head units from 2016 and up Civics.
Ah... Gotcha. Thank you so much for the info!
nasserss
Post by nasserss »
Is there any plans in the future to make it work with Aftermarket HU
No plans to do so. The protocol is public if people wish to make their own app.
HMontanez
Post by HMontanez »
Hi, The APK works on a 2021 CRV headunit? thanks.
HMontanez wrote: Thu Feb 23, 2023 12:45 pm Hi, The APK works on a 2021 CRV headunit? thanks.
Is it supported by HondaHack?
HMontanez
Post by HMontanez »
Spunkster wrote: Thu Feb 23, 2023 1:20 pm
Yes
Then it should allow you to install it.
We've never tested on a CRV. Honda may have changed the pairing requirements from the Civic, so there's no guarantee it will work.
berserkfc3
Post by berserkfc3 »
hello, i recently bought a flashpro and i can't connect it to my cars bluetooth or in the hondata app through honda hack. i've tried resetting the pairing codes, turning on alternative pairing, everything. it says connecting to null, connecting fails and then terminates the program. it connects just fine to my iphone hondata app. any tips?
What is the version of the app on the head unit?
berserkfc3
Spunkster wrote: Thu Oct 31, 2024 9:09 am What is the version of the app on the head unit?
The version is 1.5.4.1
Is there a way to download an older version of the software on either the head unit or the actual hondata plug in so that it can work? It won't pair to the car at all, I've reset the pairing codes, tried 0000 and 1234 on each and nothing has worked.
You must use the most current version at: https://www.hondata.com/updates/link.php?app=dash
berserkfc3
Spunkster wrote: Mon Nov 04, 2024 4:04 pm You must use the most current version at: https://www.hondata.com/updates/link.php?app=dash
same issue, won't connect. the flashpro won't connect to the car at all, it says a chain of 5-6 numbers and says to compare or confirm them on the device, and then cancels the connect. is it a the version on the flashpro that could be the issue? it's fully updated on the last release patch available.
What is the actual version of the app on the dash?
Ralleyered18
Post by Ralleyered18 »
Actually have the same exact issue in my 18 type r. Same thing when attempting to pair the flashpro via the car’s Bluetooth settings. Random code that requires action on your phone(flashpro). But the flashpro has no way of interacting, it times out, and fails.
