Head unit dash app does NOT connect to the flash pro
Exort321
Re: Head unit dash app does NOT connect to the flash pro
Post by Exort321 »
Vehicle model and year: 2018 honda civic type R
Dash software version:1.6.0.0
Flashpro serial #:FP-CTR-357082 2017+ civic type r americas
Flashpro firmware version:V4.3.2.0
Pairing code in flashpromanager software: 1234
Pairing code on my head unit : fixed 1234
Alternate pairing mode status: ✅ checked
I tried pairing code :0000
Do you have the alternate pairing mode enabled?
Exort321
Post by Exort321 »
Yes as i said alternate pairing is checked on the flashpro application
Will it connect to the mobile app on your phone?
Exort321
Post by Exort321 »
Yes it connects to mobile app no problem. Ive also tried bluetooth connection on the flashpro and laptop and its working . Its just the head unit bluetooth to the flash pro is not working
Hold the power button on the head unit until it asks to reboot, then reboot and then try to pair it after rebooting.
Exort321
Post by Exort321 »
I have done that multiple times. Even had factory reset it and tried to pair still the same issue wont connect , even after rooting the head unit with honda hack still wont connect .
Exort321
Post by Exort321 »
Anything else?
Send and email to support<at>hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
Exort321
Post by Exort321 »
Im suprised you’d do an RMA when my flash pro would connect to phone no problem or laptop via bluetooth and would also connect to a mobile app hondata . 🤷
steezyleo
Post by steezyleo »
Unfortunately having the same issue. Just sent an email today so hopefully I hear from them soon.
joecat66
Post by joecat66 »
maybe this helps as i just went thru this process today
you have to go into the flash pro software and enable the 2018 box under bluetooth (for me anyway mine is an 2018 civic si)-also make sure your firmware is updated--i did everything on my pc and used the printer cable connection not the usb for the flashpro updates. hold and reboot the audio button to reboot things after each change once connected to obd
here is the key i found ----make sure the car is in ignition position 2 ie ready to run when you hit the start button--not accessary mode--when pairing the flashpro for some reason it would not find it otherwise--no code needed when i did this set to 0000 default
hope that helps-i am a 57 year old geezer!--gauges on headunit now function w/hondata apk--i hacked my car 5 years ago and my flashpro is also 5 years old pleasantly surprised it had bluetooth!!
joecat66
Post by joecat66 »
also the flashpro must remain connected to the obd for this to work
Saint
Post by Saint »
for those who have submitted an RMA form. have you guys gotten any help. i’m not sure how that would be useful, it’s just trying to get around the pair code on the head unit. it sucks when you follow all the instructions and it won’t work. the head unit just won’t allow the connection without asking for pairing code. please if someone has come with a solution here in 2025 please let me know. this thread has gotten quiet and i see nothing saying the problem is fixed
shadow_bold
Post by shadow_bold »
Hello everyone,
I’m facing the same issue. All my apps are updated, including the FlashPro Manager and the Hondata app for the head unit. However, I can’t pair the FlashPro Mini with the car. I’ve tried adding the device through the Bluetooth menu in the app, made sure the “alternative” menu option is checked, and set the PIN to the standard 1234. But I keep getting an error message saying it can’t pair with the FlashPro unit.
Does anyone know how to fix this?
I just bought the FlashPro Mini a month ago.
Thanks a lot! 🙏
