SManager V1.5.3 beta
V-Spec race development
Re: SManager V1.5.3 beta
Post by V-Spec race development »
My issue w/ the new version has not even taking care of since last time I posted.
Tested and works correctly with 1.5.3.
TheWickedOne1
Post by TheWickedOne1 »
Hondata wrote:Tested and works correctly with 1.5.3.
Very interesting, gonna try a back up laptop tommorrow.
Ok, we've found the problem - it is from Vista Virtualization.
The work around is to install a copy of SManager into a directory other than program files.
We will fix this shortly.
TheWickedOne1
Hondata wrote:Ok, we've found the problem - it is from Vista Virtualization.
Nice, Thanks for pursuing.
My main laptop I use was originally Vista, but upgraded to W7 ultimate 1+ years ago.
G. Eng
Great job!!! thank goodness you finally found the problem. I know I'm not going crazy lol.
sw-ef
Post by sw-ef »
im using windows 7 what do i have to do to fix the issue uninstall nd reinstall? and where?
TheWickedOne1
sw-ef wrote:im using windows 7 what do i have to do to fix the issue uninstall nd reinstall? and where?
Uninstall Smanager, when you run the .exe again the default installation to C:\Program Files\SManager will show up, just browse and create a new folder elsewhere perhaps under Windows and install it there.
MarkC
Post by MarkC »
Thanks for the Overrun Fuel Cutoff (MAP) table. I have always had a problem with extremely low throttle inputs causing the DFCO to activate prematurely. After a slight adjustment I no longer have the issue. That and the other improvements made me very happy. :)
TheWickedOne1
Can you guys review if parameter tracing is supposed to work on the Pressure Vs Duty table on the boost control tab. I could've sworn it used to work while reviewing a datalog or realtime, i see it highlighted at 25% but doesn't move anywhere The paramenter tracing does work for the boost x RPM x Gear table.
G. Eng
ITR1102
Post by ITR1102 »
Not sure when it was added, but THANK YOU for the copy/paste function that I noticed in the most recent Beta.
TheWickedOne1
TheWickedOne1 wrote:Can you guys review if parameter tracing is supposed to work on the Pressure Vs Duty table on the boost control tab. I could've sworn it used to work while reviewing a datalog or realtime, i see it highlighted at 25% but doesn't move anywhere The paramenter tracing does work for the boost x RPM x Gear table.
G. Eng
Spunkster/Hondata - Have you guys had the oppurtunity to look in to this ?
No, it is not supported
Any future plans to have this added?
It cannot show tracing because the target boost is not datalogged.
