Head unit dash app does NOT connect to the flash pro
Re: Head unit dash app does NOT connect to the flash pro
What year is your vehicle
zhen1243267350
Post by zhen1243267350 »
Vehicle model and year: 2018 honda civic type R
Dash software version:1.6.0.0
Flashpro serial #:FP-CTR-357689 2017+ civic type r americas
Flashpro firmware version:V4.4.9.0
Pairing code in flashpromanager software: 1234
Pairing code on my head unit : fixed 1234
Alternate pairing mode status: ✅ checked
I tried pairing code 0000, clicked pair for more then 3 times still throw out random codes and ask me to match up.
Will it connect on your phone?
Hold the power button until it gives the option to reboot the head unit and then wait for it to reboot and try again.
zhen1243267350
Yes. I can connect it to my iphone. And I tried reboot, but it doesn't work.
What paring code setting do you have set on the head unit?
shadow_bold
Post by shadow_bold »
Vehicle model and year: 2021 Honda Civic Type R European Version
Flashpro serial #:FP-CTR-INT-372816 2017+ civic type r Outside Americas
Main Verion:262
Pairing code in flashpromanager software: 0000
Pairing code on my head unit : fixed 0000
I tried pairing the FlashPro via Bluetooth with my MacBook Pro M2. It sometimes detects the device, connects briefly, and then disconnects. My iPhone 14 Pro doesn’t detect the FlashPro Bluetooth at all. The car’s system sees the device but cannot connect to it.
In the FlashPro Bluetooth menu, nothing is displayed (see picture below). I believe this may be an iOS firmware compatibility issue with my device.
Please help.
Why are you pairing with a macbook? It's not going to work because the BT stack is different on the mac vs windows. Note how no local address is shown.
shadow_bold
Hello,
That is my only option for the moment as a laptop ! I have windows 11 installed on it on a virtual machine ( vmx)
But what about the iPhone connection ?
Why it does the same as with the car ( Bluetooth found, cannot connect to it ) ?
Thank you !
Ps: How to generate local adress ?
in the settings in the app on the iphone do you have connect with response enabled?
zhen1243267350
Spunkster wrote: Tue Jun 10, 2025 10:41 am What paring code setting do you have set on the head unit?
i tried 1234 and 0000
shadow_bold
Hello !
Any new updates ?
I have switched to a windows pc and still the same issue( cannot connect the flash pro mini to the car Bluetooth )
Thank you
BV1
Post by BV1 »
Same issue here, Honda Head unit Jailbroken... Hondata APK installed, pairing code set to fixed, 1234. Alternative Pairing Mode 2018+ Checked in FPM, car is indeed a 2018 FK8, but... no matter what, FlashPro will not pair. It detects in both the Hondata Mobile... and in Headunit Bluetooth search, but neither one will pair. Running 4.5.1.0
Steve
Student: There's no replacement for displacement!
Teacher: HP is essentially Torque * RPM.
Student: <?>
Teacher: So, technically there is no replacement for RPM either.
Will it pair to your phone?
bakedbean
Post by bakedbean »
I'm sharing my experience here because I'm having the same issue with the Dash app not connected via BT to the Flashpro Mini and crashing on the 2021 FK8 head unit. The difference for me is that I purchased the new unit from an Australian reseller in 2025, and it has never worked.
From what I can see, this issue has been running for quite some time now, and a lot of impacted folks.
Vehicle model and year:2021 FK8
Flashpro firmware version:V4.5.2.0
Pairing code on my head unit: Fixed 1234
I engaged Hondata support, and they asked me to send the FP mini in and include my credit card details on the form. Honestly, putting those details on a form is out of line in today’s climate of fraud and data breaches. I reached out to the Australian agent who sold me the unit, hoping they’d have some pull, but no luck there either. Hondata suggested that the workshop conduct more testing before returning it, as they would also incur costs for shipping and other expenses.
What is there to actually test?
So here we are, waiting and wondering if Hondata will actually address this issue. For me, I’m seriously considering returning the unit and going in a different direction, purely on principle. The support process feels outdated and overly skewed toward Hondata charging customers to fix bugs they introduced through software updates. That’s not something we, as users, have any control over.
Am I wrong for expecting better? Out of line for calling this out?
