Problem with Fan always on (MY06+ S2000)
eternallx
Post by eternallx »
Hey I have a base tune from my tuner and a final tune.
However when I load my final tune the fan stays on constantly with the key in the ignition.
This goes away if I load the Hondata KW tune or the base tune.
Please have a look at the kals. The fan is set on at 168 degree on both kals.
keto06
Post by keto06 »
whats the problem with the fan being on?
the fan is set to come on too early. change it to 190 or 195.
keto06
Post by keto06 »
whats the downside of the fan coming on "too" early?
jamesandrew58
Post by jamesandrew58 »
its set to 168 so it will be on all the time when the car is warmed up
eternallx
Post by eternallx »
Spunkster wrote:the fan is set to come on too early. change it to 190 or 195.
It doesnt matter what I set it to in the final tune. It will still run when the key is in and the ect is only 100 degrees or less.
Like i said the fan only kicks in at 168 on the base tune. which is how i would like it on my final tune.
I set it to 168 to match my lower temp thermostat.
So you see no other problems with the kal?
eternallx
Post by eternallx »
keto06 wrote:whats the downside of the fan coming on "too" early?
when its 60 and below outside the car never warm up even after sitting for 15 minutes.
We also advise against using colder thermostats.
http://www.hondata.com/forum/viewtopic.php?t=9845
Post your calibration and a datalog showing the problem.
keto06
Post by keto06 »
I know for me i live in texas, so I dont have to worry about the engine heating up...
