Do I need knock sensor...
Tsuchinoko
Post by Tsuchinoko »
...to use with the ITR 01 stock base map?
I making this question because I don't have knock sensor and the timing on this map seems a bit agressive. Is it safe to use without a knock sensor?
Those who know don't tell, and those who tell don't know.
You don't need it and you can only use one if you have an ECU with knock control.
Tsuchinoko
That is good news.
