K20A help.
aspecha
K20A help.
Post by aspecha »
I swapped a K20A into my EM.
I have the following bolt on's:
K20A DC5-R Engine
DC 4-2-1 Headers
2.5IN ... Exhaust right from the header.
Short Ram Intake
My car's running rich. I get a black exhaust buildup on my back bumper. I'll post up my map when i get home, and how do i datalog to post that as well?
dcloo
Re: K20A help.
Post by dcloo »
aspecha wrote:I swapped a K20A into my EM.
K20A DC5-R Engine
DC 4-2-1 Headers
Short Ram Intake
send it to dyno tune great for FC & WHP
You will get a dirty bumper without a cat.
jamesandrew58
Post by jamesandrew58 »
get me a 3rd gear WOT datalog from 2k to redline and attach that and your tune.
aspecha
Post by aspecha »
here's the tune/datalog
jamesandrew58
the datalog shows you running SUPPPPER lean. idk if its just me.
aspecha
Post by aspecha »
oops maybe im backwards, i decreased my fuel map and the ratio went down??
aspecha
Post by aspecha »
think anyone can revise the tune for me so the AF isn't so messed up?
jamesandrew58
ditch the current tune and upload the k20a-itr tune again without making adjustments. (except for those thats needed to make the car run.)
then save that tune and datalog 3rd from 2k-redline again and post it up
aspecha
Post by aspecha »
I didn't touch the fuel/ignition on that map if i'm positive.
jamesandrew58
here you go. datalog 3rd for me
cranny
Post by cranny »
start from scratch , load the ITR calibration and tune from there. load the ITR calibration and post up at least a 20 minute datalog with a WOT 3rd gear pull somewhere it in. make sure its in open loop.
aspecha
Post by aspecha »
Alright I'm going to start from scratch with k20a itr basemap. The only thing I'm changing is putting vtec to 5000-5400, and down the road I was going boost so I have the hondata map sensor. When I start the car the af doesn't move at 10.7 then jumps to 27 and goes up one by one to 32. I'm not throwing a code for my o2 senors and I only have a primary. Would anyone think the wiring could be off or the map sensor not being stock with boost could be messing the af up?
aspecha
Post by aspecha »
And if I didn't mention I have a k swapped 01 civic (em2). I used xproductionz kswap guide to wire my primary o2 sensors if anyone needed more information. Thanks for your help.
cranny
Post by cranny »
something isnt right if its hitting 30:1 at idle. and dont set your vtec any higher than 4500.
