just getting started
b-wayne
Post by b-wayne »
my buddys and i are about to get our selfs a 91 crx and want to drop a b18c1 from a 96 intgera. we are wanting to turbo it and push between 10-20 pound of boost. now what system should we use and how hard is these programs to use??
Just getting started
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
b-wayne
Post by b-wayne »
thanks man now how hard is it for someone just getting started to tune a ecu from the programs
That all depends on the person using the software. You can download the software and take a look at it to see how it works.
b-wayne
Post by b-wayne »
which program should i download to check it out
Smanager
