PA Atmospheric Pressure Sensor
hermit9832
Post by hermit9832 »
Is this sensor bypassed when using Kpro? I have noticed that it does not change at all when I travel. I have gone from 8K elevations to sea level and the freaking sensor just says 95.0 kPa. It really screws with a tune when you go cross country like that, I've had to add as much as 10 to 12% fuel just keep things in check.
It is only disabled if you turn off OBD2 emissions checking
Remember that the MAP sensor will compensate for changes in elevation.
