hard to start when semi warm
rsamd1
Post by rsamd1 »
mods: k20a2, prb kpro, 750cc, jrsc 7psi, i/h/e
When i start the Car in the morning it starts fine after first cranking. When the Car is semi warm like 40-50C oil temp and warm outside it needs cranking a few times till the engine starts or idle is very low 200rpm 2secs and then it idles fine. Is there any solution for this plz?
Try adjusting the cranking fuel trim in parameters.
rsamd1
Post by rsamd1 »
Cranking fuel +/-10% does not help. reducing injector pulse in 41c-61c range seems to help a bit.
try larger changes to the cranking trim
rsamd1
Post by rsamd1 »
Reducing actually got worse, i try add some 25% or so. thx
rsamd1
Post by rsamd1 »
adding +30% didnt helped. only got worse.
Bonny
Post by Bonny »
Mods: k20a2, PRA k-pro, jrsc 7 psi, 650 cc
I have the same starting problem. The car is almost too easy to start when cold or warm, but difficult to start when semi-warm (after it's been turned off for about 30 minutes or more).
Increasing cranking fuel by 10% makes no difference at all.
Increasing cranking fuel by 30% makes the car even more difficult to start when it's semi-warm.
Reducing injector pulse (ms) for 41C and 61C helps. I started out with 19.53 and 14.65. I have now reduced the values to 14.53 and 9.65. The car doesn't start perfectly, but it starts a bit faster.
Any ideas?
rensoyka
Post by rensoyka »
it's not unusual to reduce cranking fuel trim 20-30 % with larger injectors. I run -10% with only 410cc injectors. I can't see any applications where you would add fuel to the cranking trim.
Axix23
Post by Axix23 »
let me guess, rc injectors?
I had the same issue with mine, got rid of them and running bosch, never had a problem...
Bonny
Post by Bonny »
Yes, I'm running RC injectors.
I still haven't gotten rid of the starting problem when the car is semi-warm.
I might just try bosch injectors instead.
