please help with my first datalog
Posted: Mon Sep 28, 2009 11:37 am
Hi all, my name is Ben and i'm from Middlesbrough in the UK.
I have recently fitted a UKDM k20a2 into a 98 spec JDM ITR.
I am using a prc k-pro, RBC intake, DTR/SSR header, IPS K2 cams, crower springs, Ti retainers, lightened flywheel. At the moment i have a temporary warm air intake and am using the stock dc2r exhaust.
Here is the a copy of the Map i have chosen as the basemap as it is the one that most closely resembles my setup and my first datalog. (while out i noticed my vss wasnt reading so if thats how you tell what gear i was in then the first pull i did was in fourth, then i turned around, did a bit of a third gear pull, slowed a bit and did a bit of a fourth gear pull). and also a copy of my first datalog
ok i wrote the above, attached my kal ok but get an error when trying to attach my datalog? any ideas anyone?
Thanks in advance for any help.
Cheers, Ben
Cheers, Ben
