KManager V1.3.8 beta
Download here
Changes:
• Changed ignition tip in retard to fix retard oscillation.
This fixes a bug in the Honda ECU code which results in the ignition rapidly going up and down upon throttle tip in. Most cars do not show this problem. See http://www.hondata.com/help/kmanager/ge ... meters.htm for more information.
Ice71
Post by Ice71 »
Great work Doug,
I'll try it next week cause I've a customer's car with this problem.
Slip_Angle
Post by Slip_Angle »
My ECU has this problem.
Curious if there is any net effect of having this issue?
chrisfjr83
Post by chrisfjr83 »
I hope that this fixes my problem that I am having on my car with Idle surging really after I beat on my car some. I can daily drive the car fine but after I beat on it just once by taking the RPM's to redline my car idle surges like crazy. Almost so bad that I hate to drive the car because I will be sitting at a light and my idle jumps back and forth between 1000 and 3000 rpm's. The only way that it fixes itself is if I let the car sit and cool completely down before I drive it again. VERY WEIRD problem.
jiayong
Post by jiayong »
Has the file been removed? I cant seem to download it
It has been release. The latest beta is here http://www.hondata.com/forum/viewtopic.php?t=10279
jiayong
Post by jiayong »
I see. Thats odd.
On hondata.com, the download is still version 1.37
jiayong
Post by jiayong »
K-Pro KManager
Mapping and datalogging software for the K-Series Programmable ECU. 6/23/2009 4.4 MB V1.3.7
10/22/2009 4.4 MB V1.3.9 (beta)
This is what I see. 1.37 and 1.39 but there isnt 1.38.
If we make any changes to the beta version we increase the version number and release a new version. Thus 1.3.8 became 1.3.9
Bubaluke39
Post by Bubaluke39 »
Hello everyone, I just join this forum and I wanted to know if the new version of Kmanager will work with windows 7 64-bit. I am lookin into a new laptop. Thanks in advance.
05 VBP Type-S
MODS - I/H/E K-Pro Tuned by Jeff @ Evans Tuning
RBC, BC stg2 cams this spring...
Yes, XP, Vista and 7 all versions.
Bubaluke39
Hondata wrote:Yes, XP, Vista and 7 all versions.
Thank you very much
05 VBP Type-S
Bubaluke39
Thank you very much
05 VBP Type-S
