trouble with cold start
mugen715
Post by mugen715 »
hi,
my h22a civic having trouble with cold start.I can't start my car in the morning. I have to use my stock ecu p13 tto warm up my car. After the car has warm up, It is easy to start with s300 ecu. I attach my datalog to you. Could you help me to check what wrong with the cold start?Everything is fine with the air fuel ratio throughout the rpm range except this cold start. My h22a engine mod is:
skunk2 camshafts pro-series stage 1
skunk2 intake manfold
70mm throttle body
high compression piston (11.5 : 1)
thanx
allm0t0rGSR
Post by allm0t0rGSR »
thats not the datalog thats the calibration?
Why is your cranking fuel trim at 100%?
Thats doubling the fuel it should have at startup.
mugen715
Post by mugen715 »
hi,
sorry, yup it is calibration.Initially im using 50% for my cranking fuel. But it cannot start up. THat why im increase it to 100%. But still can't start up. What do you think the problem?
start with the cranking fuel at 0.
lowblow
cold start
Post by lowblow »
You need more air not fuel for cold start
