RSX wideband 02
thesilverbullet
RSX wideband 02
Post by thesilverbullet »
can we simply replace the primary 02 with an rsx wideband 02 to street tune a/f?
sorry about the dbl post
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
The S2000 o2 is a wideband - you don't need to change to a RSX o2 sensor (it won't work if you do).
thesilverbullet
thank you
'23 RDX SH-AWD
Garrett_si
Post by Garrett_si »
Hondata wrote:The S2000 o2 is a wideband - you don't need to change to a RSX o2 sensor (it won't work if you do).
since 2006?
because s2000 00-05 are narrowband
Garrett_si
http://www.hondata.com/kpro_dual_ecu_s2000.html
Are there any other costs?
Yes. The K-Pro requires the primary (front) oxygen sensor/ air fuel sensor from a US 2002-2004 RSX or US 2002-2005 Civic Si as the stock S2000 front sensor is incompatible.
36531-PND-A11 is the front sensor from a 2002-2005 Honda Civic Si or
36531-PRB-A01 is the front sensor from a 2002-2004 Acura RSX.
This is a plug in replacement. You purchase this from your Honda or Acura dealer.
You are confusing the Dual adpater which requires the RSX sensor with the FlashPro which requires the stock S2000 sensor.
Garrett_si
Spunkster wrote:You are confusing the Dual adpater which requires the RSX sensor with the FlashPro which requires the stock S2000 sensor.
you said the stock s2000 02 is wideband
right?
scareyourpassenger
Post by scareyourpassenger »
If the stock sensor is a wideband then why is there instructions for hooking an aftermarket one up?
The stock o2 sensor is a wideband, but is not as accurate nor does not have the range of an aftermarket wideband.
scareyourpassenger
I am guessing this isn't an option on the s2k since it is not listed as a supported feature and the pins are available for civic owners only.
