allm0t0rGSR
Posts: 116 Joined: Tue Jun 23, 2009 10:51 pm
Post
by allm0t0rGSR » Thu Oct 15, 2009 12:40 am
why is my boost vs rpm vs gear is set to 0.01... but i save it like 70 each table.... can anyone tell me why it does that ?
Martian
Posts: 169 Joined: Sun Aug 20, 2006 4:23 pm
Post
by Martian » Thu Oct 15, 2009 12:53 am
because the highest value in your pressure vs duty cycle is 11.5. So it has no idea what 70 is and defaults the value. You need to input what psi you want in that table per gear/rpm.
thank you, thank you, I'm here all week
Posts: 10666 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Thu Oct 15, 2009 8:01 am
With V1.4.3 there are two values the boost by gear tables can contain:
- target boost (this is how previous versions worked)
- duty cycle (a new option 'Gear Based Duty Cycle').
If you want the old functionality, select 'Gear Based Target Boost'.
allm0t0rGSR
Post
by allm0t0rGSR » Thu Oct 15, 2009 8:41 am
i want to use the Gear Based Duty Cycle because my psi dropped at high rpm....or this feature is no use?...
Post
by Hondata » Thu Oct 15, 2009 9:07 am
I think you just need to enter the duty values into the table. They default to 0.1% because (due to space limitations) the same table is used for both target boost and duty cycle.
allm0t0rGSR
Post
by allm0t0rGSR » Thu Oct 15, 2009 5:44 pm
is there anyway u can fix it with the next version? it would be great because u can run it with the same psi as the rpm increased.... thanks
Post
by Hondata » Fri Oct 16, 2009 8:11 am
What, exactly, are you trying to do, and what is not working?
allm0t0rGSR
Post
by allm0t0rGSR » Fri Oct 16, 2009 3:33 pm
im able to save 70 or over duty cycle on my calibration before clossing the smanager, but when i opened again it shows 0.01
Posts: 24373 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Fri Oct 16, 2009 3:48 pm
You must tell us exaclty what you are doing step by step.
allm0t0rGSR
Post
by allm0t0rGSR » Fri Oct 16, 2009 9:21 pm
ok at boost control, i set it to normall closed at solenoid configurationm and gear base duty cycle at control method and 5 psi at activation pressure...at boost vs rpm vs gear i set it to 70 each and save and closed the smanager... but the next time i opened, it show to 0.01?
Post
by Spunkster » Mon Oct 19, 2009 2:11 pm
We will look into this and see if we can reproduce this.
Post
by Hondata » Wed Oct 21, 2009 2:05 pm
Fixed a save/reload problem, download and isntall V1.4.4
