Nitrous Aux3 bug
GTMcoupe
Nitrous Aux3 bug
Post by GTMcoupe »
Gents have you fixed the following bug in ver 1.4.3 I just found with Ver 1.4.2.
The values you input into Nitrous/aux 1 for ignition timming are copied into Nitrous/Aux 3 when you reopen the file after saving
the same thing happens if you alter Aux 3 and save, close reopen the values are copied to aux1
West
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
GTMcoupe
Post by GTMcoupe »
Just looked at the fueling side and this is doing it too on Aux2 and Aux3 simular thing copying values between the two after closing and reopening.
Playing around with two nitrous kits at the moment and this is causing some issues.
West
Thanks for the report. I've found and fixed the bugs.
I will update the beta version in the next day with other changes; these bug fixes will be incorporated into the beta release.
GTMcoupe
Post by GTMcoupe »
Thanks Guys
Top work
West
