SManager V1.4.4 beta
We have had very little feedback on the changes to the boost control in V1.4.3, so the next release remains in beta.
Download here
· Fixed nitrous 3 fuel & ignition load & save behaviour.
· Added Ignition Dwell angle tables.
· Added Injector Phase angle tables.
Ignition Dwell. This was added so that turbo people can increase the coil change time to see if that gives a stronger spark. Be careful, as a longer dwell time will heat the coil up a lot more.
Injector phasing. It may be possible to gain a small amount of power by changing the injector phase. It may also be possible to improve the idle quality. Let us know.
Update 10/26/2009: V1.4.4.1: Fixed load/save of boost control duty cycle table.
m_sasso
Post by m_sasso »
As always thanks!
RockStarTuning
Iteresting concept.... Injector phasing
Post by RockStarTuning »
"Injector phasing. It may be possible to gain a small amount of power by changing the injector phase. It may also be possible to improve the idle quality. Let us know."
Think I have a project to play with this weekend!
Let you know my thought after testing this weekend!
Thanks HONDATA!
GTMcoupe
Post by GTMcoupe »
Gents forgot to say thanks for fixing the nitrous3 save behaviour.
Apeared to be working ok when I used it at the drags the other month. I feel it helped me gain the new PB of the day, allowing me to experiment with an idea i had. Unfortantly I hurt the motor at the end of the day but all seems to be working on the Nitrous controls, from the datalogs.
West
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
LDLSPEED
Post by LDLSPEED »
THANKS! Very happy with the results specially the coil dwell........appreciate the hard work you guys put in.
newsoltsc
Post by newsoltsc »
Hi,
Just curious on when the next SManager update would be. Also what will be updated?
8)
-Jose
