ECU went into safe mode. P0107 code
soxfan143
Post by soxfan143 »
Hello Hondata. Today while doing a 3rd gear WOT log, my ECU went into safe mode. I Got all the way through the 3rd gear pull to about 8300-8500rpm and when I shifted into 4th and coasted for a bit the CEL popped on and it would not respond to throttle input above 3K rpm. I cleared the code and cycled the ignition off and restarted the car and it is operating normally so far. Could it just have been a weird 1 time thing?
I have the log and I will post it up. The code says MAP absolute pressure sensor low voltage. I'm also running your 4 bar map sensor and was wondering if it could be a faulty sensor? Thanks.
Your engine is making more vacuum on overrun than mine, so the MAP voltage is a little lower. I've revise the software to accept a lower voltage.
soxfan143
Post by soxfan143 »
Gotcha. So should I redownload the software again? If so let me know when it's all set. Thanks for all your support.
