CEL Help plz!
newsoltsc
CEL Help plz!
Post by newsoltsc »
So I got my s300 ecu installed and it reads I have 3 codes.
1) o2 sensor (I have it unplugged so thats that code.)
2) 9 CYP - cylinder sensor (where the hell do I start to fix for this??)
3) 20 Electrical load detector (stumped on this one as well... wtf?)
Any ideas on fixes??
::Backround::
Specs:
Stock D16Z6 w/ 227 miles.
Turbo:
SP Log Mani, 2.5" DP to stock exhaust, Garrett 50trim, 38mm Tial, Stock 240cc injectors, stock fuel setup.
Im also running NGK 7s.
TIA!
-Jose
megomaniac
Post by megomaniac »
2) CYP is a sensor in your distributor
H22A4
turbo
S300
newsoltsc
Post by newsoltsc »
megomaniac wrote:2) CYP is a sensor in your distributor
Ahh mmk. Ill check the wiring for the dizzy.
-Jose
Does your car have an ELD?
newsoltsc
Post by newsoltsc »
Spunkster wrote:Does your car have an ELD?
Hmmm... Good question. Not that I know of.
It's a stock 93 si hb. All obd1.
-Jose
newsoltsc
Post by newsoltsc »
So I did a little research and someone said that corrosion on the cable linking to the alternator can cause the ELD.
I do have a lot of Blue stuff on the positive side of the battery.
Ill clean that off and see what happens! :?
-Jose
newsoltsc
Post by newsoltsc »
Ok so I cleaned the battery terminals and still get the ELD cel.
So I just disabled it in the S300 haha!
So now just CEL 9.
Hmm... Maybe I'll pickup a new dizzy next week and see if that fixes it!
-Jose
You need to find out if your car ever had an ELD in the first place.
newsoltsc
Post by newsoltsc »
Spunkster wrote:You need to find out if your car ever had an ELD in the first place.
Good question.
How would I be able to tell if my car came equipt with ELD?
There is no "plug" or "fuse" to look for from what I've read.
I found this:
"Beginning with the 1990 model year, certain Hondas were equipped with an Electronic Load Detention (ELD) module which was designed to improve fuel economy by almost shutting off the alternator during light throttle and idle. If the module fails, the ECM loses a sensor and the vehicle may experience stalling, rough idle, or low / no alternator output. Fault code 20 will be set."
I also found this:
"check the vin...if the car was made in Canada they do not have an ELD."
My car was made in Canada.
I've read several posts that replacing the Fuse Box inside the engine bay will clear this code.
I really dont "feel" or "see" a difference with this CEL on. It could be the p28 I bought has the "ELD Chip" installed on it. I've read that some have them and some don't.
I can't refer back to my old ECU because I recently sold it.
-Jose
Then just disable the ELD error in Misc under Parameters.
newsoltsc
Post by newsoltsc »
Spunkster wrote:Then just disable the ELD error in Misc under Parameters.
I did haha! Thanks!
Ill replace the Dizzy and see if that clears the CEL 9. Ill keep this thread updated!
Thanks again for all the help!
-Jose
