How to tune tip-in and tip-out??
chrisfjr83
Post by chrisfjr83 »
I have been having having issues with my car bogging and jerking when getting into the throttle and letting out of the throttle and was wondering how to tune my tip-in and tip-out? Any help would be greatly appreciated. Thanks
chrisfjr83
I have already done that and nothing has changed on my tip in and tip out so what else can I try to try and eliminate the problem?
chrisfjr83
why do we not have tip in and tip out controls like s300???
chrisfjr83
does no one have any response to this
6spd_ek
Post by 6spd_ek »
what throttle body are you using? have you looked at a datalog to make sure the TPS is reading properly?
chrisfjr83
I am using my factory throttle body. and I have looked at a data log and everything looks to be working correctly.
f1racr
Post by f1racr »
Not sure if it's exactly the same issue, but ever since I've had my K-Pro the car's had a terrible hesistation when at lower RPM (below 2500rpm) and only using light throttle. When you accelerate hard it would stutter for a matter of maybe half a second then pickup and all was well.
I thought I'd missed something in the tune and spent a while reviewing but then it seemed that it was a bug.......after logging some data we could see the timing go into negative numbers, then fluctuate up and down, then finally start pulling the numbers you'd expect.
There's a fix for my exact issue here........ http://www.hondata.com/forum/viewtopic.php?t=10162 which did resolve my issue........ maybe you're having the same thing ?
Hope it's a help.
taitcw
Post by taitcw »
Hi ppl,
I daily drive a lot (traffic jam). At low RPM (<1500) + Gear 1, engine can rock like mad. I believe it has something to do with fuel cutoff.
After I checked the "Disable fuel over-run cutoff delay" item under [Closed Loop] tab, the problem seems to be gone.
Observation:
After the setting change, there seems to be a delay in fuel cut after I release the gas pedal (~0.5s).
Hope this info helps.
DT
