NEED HELP, Closed Loop Problem!!
garrettrs
Post by garrettrs »
Hello,
I really need this going for a emmisions test here in Europe!
This will be on rollers and most important is the acceleration from a bout 50 to 90 km/h.
The problem is, that i want the closed loop to stay activated and make me a clean 14.7 up to a bout 50% of throttle opening. It works very fine up to a bout 20% but after it just doesn`t regulate enymore to the dired afr.
The car is a Honda Civic D16A, with a greddy turbo kit.
Clossed loop is now set to work up to 1.4 bar (but it doesn`t).
Help very much needed!!!!!
VT-Doo
Post by VT-Doo »
You need to at least post up your calibration, a datalog will help too.
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
garrettrs
Post by garrettrs »
here the map
You should not run closed loop in boost.
garrettrs
Post by garrettrs »
Yes, on wot it shhould be deactivated, but i would like it to run cloosed loop until about 40-50% of throttle opening! so it stays about on 14-14.7 AFR, which is needed for this specific emmission test!
