new to kpro need some info
Lance
Post by Lance »
i've loaded up the base map for a d17a1 non vtec that had the 310cc injectors for a turbo set up. i changed a few parameters like set it to 525cc injectors and so on. When i start up it has long cranking then when it does start runs rough and burns rich.!! is this normal until i get it tuned properly and what can i do to make it run better before its tuned??? thanks for any input
It needs to be tuned if you have put in larger injectors. You may also have to wire in a resistor box if they are not saturated injectors or you will damage the ECU.
Lance
Post by Lance »
ok so then how it is running is normal and some tuning is needed!!!
